kayas257
Yocto petalinux build
Hello All,
I am trying to build petalinux image in yocto, I came across a weird issue unable to figure out. Issue is when I create a fitimage with custome kernerl module I get image size as 30mb, but of I add kernel module, the size goes by 100 mb i.e. 130 MB. Can any one help figure out what mistake I have made..
PS: only rootfs size is increasing
Thanks & Regards,
Kayas Ahmed
kayas257
After digging little more into the issue, I found that when I include any kernel module, /boot folder is populated with all the kerne imagel in rootfs , which is causing it to increase the size..
How do we tell yocto not to include any kernel images in /boot directory, any idea?
--updated
I did solve the problem by adding post_rootfs_processing
Thanks & Regards,
Kayas Ahmed
stephenm
can you post your fit image please?
Also, you can see the one that is generated by petalinux in the work folder, and compare
kayas257
Hello @stephenm
I did compare with image generated with petalunux, but petalinux generates smaller image like 43 mb campared to what i am generating from yocto.
I feel issue is because of kernel modules, when I add them like IMAGE_APPEND_INSTALL="kernel_module" the image size increases(fitimage).
Thanks & Regards,
Kayas Ahmed
kayas257
--updated
Thanks & Regards,
Kayas Ahmed
