kayas257
Yocto petalinux image
I have been trying to build a petalinux image using yocto, problem I am facing is to generate kernel fit image using yocto build system
Kernel fit image=kernel+ramdisk+devicetree
Can someone help me on this.
Tags (2)
kayas257
Thanks for reply.
I found the solution in the following link
https://forums.xilinx.com/t5/Embedded-Linux/ZCU102-Yocto-BOOT-bin-generation/td-p/897696
Thanks & Regards,
Kayas
stephenm
You can create the fit image manually, and use mkimage to create the image
Steps are shown here
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow
This can be done in yocto too. I'll dig out the recipe later.
gsatish10
check the yocto meta-**** layers support added in the build system & .conf file
output is in output/target/images/***.fit images
Thnaks & Regards
Satish G
G Satish Kumar
kayas257
Thanks for reply.
Thanks & Regards,
Kayas
