You are not inside a Petalinux project
I cannot run petalinux-config (or any other petalinux command) in my petalinux project directory. When I run petalinux-config, I get:
ERROR: You are not inside a PetaLinux project. Please specify a PetaLinux project!
This is an established project that I have successfully built images for in the past. I'm just trying to change one thing in the configuration and now it seems to not be recognized as a project.
What does petalinux use to determine whether I am in a project directory? I have confirmed that the .petalinux directory is present and it contains usage_statistics and usage_statistics_token.
How about config.project?
Hi @wdecook,
Which version of petalinux are you using? What did you change in the project?
Looks like you are executing this command outside the project directory.
Sandeep
Hi @sandeepg,
I'm running petalinux 2018.1 on Ubuntu 16.04 on Oracle VM VirtualBox
To my knowledge, nothing has changed since the last successful build.
I am quite sure that I'm running the command from the correct directory (top folder of the project). See console output below. This project is called base-plnx:
wdecook@wdecook-VirtualBox:~/proj/mti/base-plnx$ pwd
/home/wdecook/proj/mti/base-plnx
wdecook@wdecook-VirtualBox:~/proj/mti/base-plnx$ ls -al
total 32
drwxr-xr-x  8 wdecook wdecook 4096 Jun  4 19:05 .
drwxrwxr-x  7 wdecook wdecook 4096 Jun  1 10:14 ..
drwxrwxr-x  8 wdecook wdecook 4096 Jun  4 18:40 build
drwxrwxr-x  3 wdecook wdecook 4096 Jun  1 09:55 components
drwxrwxr-x  3 wdecook wdecook 4096 Jun  1 11:50 images
drwxrwxr-x  2 wdecook wdecook 4096 Jun  4 19:05 .petalinux
drwxr-xr-x  4 wdecook wdecook 4096 Jun  4 19:05 project-spec
drwxrwxr-x 31 wdecook wdecook 4096 Jun  4 18:28 .Xil
wdecook@wdecook-VirtualBox:~/proj/mti/base-plnx$ petalinux-config
Configures the project or the specified component with menuconfig.
Usage:
  petalinux-config [options] {--component <COMPONENT> |--get-hw-description[=SRC]}
Options:
  -h, --help                      show function usage
  -p, --project <PROJECT>         path to PetaLinux SDK project.
                                  default is the working project
  --oldconfig                     takes the working configuration
  -c, --component <COMPONENT>     Specify the component
                                  If no component is specified, it will do
                                  top level project configuration .
                                  If you specify a component,it will
                                  configure it with menuconfig and saves
                                  user's config fragments in meta-user.
                                  E.g. -c rootfs, -c busybox
  --get-hw-description [SRC]      get hardware description.
                                  if [SRC] is specified, look in that
                                  location for an Vivado export to SDK directory.
                                  Otherwise, this MUST be run from
                                  WITHIN the vivado export to SDK directory.
  --defconfig [DEFCONFIG_TARGET]  defconfig the specified component.
                                  It only applies to kernel for now.
  -v, --verbose                   verbose mode
Note: There is no validation for configurable components. User can provide
      any component, bitbake will throw error for invalid components.
I know that the simple answer to give here is to just remake the project, but that's a big pain in the butt. It would be nice to know the cause/solution so it can be prevented in the future.
Can you run below commands and post the terminal log.
$ petalinux-build -x mrproper
$ petalinux-config
Sandeep
Same
wdecook@wdecook-VirtualBox:~/proj/mti/base-plnx$ petalinux-build -x mrproper
Builds the project or the specified components.
Usage:
  petalinux-build [options]
Required:
Options:
                                     Default is working project.
                                     it will build the specified component and its dependencies
                                     E.g. -c rootfs
                                     E.g. -c myapp
  -x, --execute <tasks of bitbake>   Specify a bitbake task of the component
				     To know the list tasks for a component:
				     E.g. -x do_listtasks
  -f, --force			     Force run a specific task ignoring the stamps
				     Force run has to be for a component or its tasks
				     E.g. -c myapp -f
				     E.g. -c myapp -x compile -f
  -v, --verbose                      Show compile messages verbose mode
  -s, --sdk                          Build SDK ==> do_populate_sdk
  -b, --buildfile  <.bb recipe>      Execute tasks from a specific .bb recipe directly.
				     WARNING: Does not handle any dependencies from other recipes.
Usage:
Options:
Hi @wdecook,
Looks like your project files are not correct. Can you create a new project and test it to make sure you don't have any problem with installation.
Sandeep
I am able to configure and build other petalinux projects on the same machine with no problem. Just made a new test project and all went as expected.
What is used to determine whether the command is run from a petalinux project top directory or not? I read here that the tools look for the .petalinux directory. That directory is present.
@jeffsimpson
config.project was indeed missing. I copied that over from another project and we are cooking now.
Thank you.
