ZC702 load uboot and image.ub to RAM from JTAG and boot
Hi All,
I am trying to boot up ZC702 with prebuilt images by downloading u-boot.elf and image.ub to RAM. After that execute u-boot.elf and form uboot command line do "bootm to image.ub load address"
This is working and kernel is booting but file system is not mounting. It is stucking after some time. Attached log.
The same images with SD boot works fine. File system is also mounted properly but when I load images to RAM and try filesystem is not mounting.
Shyam
Re: ZC702 load uboot and image.ub to RAM from JTAG and boot
Hi @shyamthella ,
Can you please program the bitstream(system.bit) to ZC702 and try?
Best Regards
Kranthi
Hi kranthi,
I moved to ZCU102 for my development.
I will try this in free time and update here.
Shyam
