ZC706 board hangs during execution of normal linux commands such as find, tar, cp, scp, du -h
Hi All,
I am working on ZC706 based.
When I try to run simple find, tar, cp, scp, du -h commands, board hangs. I have to restart it.
when board hangs, sometimes I get kernel oops on console for ipv6 module, some garbage or nothing.
I checked the /proc/meminfo while executing all these commands . When Memfree is between 537160 kB to 542460 kB range it hangs. Total memory available on the board is 773716 kB
If I run same commands and if Memfree is more than  560000 kB, board does not  hang. It will execute the command properly.
am I missing any settings? Is there any other instead on Memory to find it's root cause?
Please help me resolve this issue.
Samiksha
