ZC706 enabling ADV7511 with Yocto
I cloned Yocto to try building a Linux image. I have poky branch sumo. I also pulled the xilinx repo and got the bsp added to my build.
This all works fine. I ran bitbake core-image-sato and I got a full complete build. I can boot with this output just fine, and am getting root access through the J21 UART port.
However, even though the OS boots up fine, I don't get any display out from the HDMI. I believe core-image-sato is supposed to come with some desktop manager, Matchbox I think? So I would like to get some sort of display out to a monitor.
What do I need to do to enable the HDMI port on the 706 board with Yocto?
Re: ZC706 enabling ADV7511 with Yocto
Hi @lm_atl,
Have you enabled below Linux Kernel Configuration
Device Drivers --->
Graphics support --->
<*> Direct Rendering Manager (XFree86 4.1.0 and higher DRI support) --->
<*> DRM Support for Analog FPGA platforms
Device Drivers --->
Console display driver support --->
<*> Framebuffer Console support
Sandeep
Voyager
Voyager
You need to install some modules from ADI(Analog Device Inc) linux repository
They are the followings
https://github.com/analogdevicesinc/linux/tree/master/drivers/gpu/drm/adi_axi_hdmi
https://github.com/analogdevicesinc/linux/tree/master/drivers/gpu/drm/i2c : adv7511.h, adv7511_core.c adv7511_audio.c
https://github.com/analogdevicesinc/linux/blob/master/drivers/clk/clk-axi-clkgen.c
I attached recipes for them
Thanks, thats very helpful!
I'm new at Yocto and trying to learn how to use everything, would it be sufficient for me to unpack the .tar you included to my computer and add the .bb files for those 3 to the bblayers.conf file? Or is there more to it than that?
Voyager
Voyager
First of all, make sure your vivado project includes logic for ADV7511
https://github.com/analogdevicesinc/hdl/tree/master/projects/adv7511/zc706
I attached my project simplified for zed board.
Then your devicetree should be like this
&axi_iic_0 {
    adv7511: adv7511@39 {
        compatible = "adi,adv7511";
        reg = <0x39>, <0x3f>;
        reg-names = "primary", "edid";
        adi,input-depth = <8>;
        adi,input-colorspace = "yuv422";
        adi,input-clock = "1x";
        adi,input-style = <1>;
        adi,input-justification = "right";
        adi,clock-delay = <0>;
        ports {
            #address-cells = <1>;
            #size-cells = <0>;
            port@0 {
                reg = <0>;
                adv7511_in: endpoint {
                    remote-endpoint = <&axi_hdmi_out>;
&axi_clkgen_0 {
    compatible = "adi,axi-clkgen-2.00.a";
    #clock-cells = <0>;
    clocks = <&clkc 16>;
&axi_hdmi_tx_0 {
    compatible = "adi,axi-hdmi-tx-1.00.a";
    dmas = <&axi_vdma_0 0>;
    dma-names = "video";
    clocks = <&axi_clkgen_0>;
    port {
        axi_hdmi_out: endpoint {
            remote-endpoint = <&adv7511_in>;
 In yocto, don't forget to add IMAGE_INSTALL_append = " adi-axi-hdmi adv7511 clk-axi-clkgen" to  core-image-sato.bbappend
