ZCU 104 : USB CDC class unable to detect
Hi ,
I am trying to connect a micro usb IMU sensor to Zcu 104 eval board working on petalinux. In a Linux PC the same IMU sensor is getting detected as CDC data class to a ttyACM device and i tried the same thing here to include CDC class in petalinux by following the below link
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841624/Zynq-7000+AP+SoC+USB+CDC+Device+Class+Design+Example+Techtip
after booting the board with the generated image. My USB port on the Zcu104 cannot power up the IMU sensor that is connected to it .
My target is to transmit IMU data(connected to Zcu104 through USB) countinuously to Zcu104 and read data received .
Can some one help me resolving the issue ?
Please correct me if my approach is wrong.
Sai
HI @suddala.s
ZCU104 board does support only HOST mode and NOT the USB device mode.
So you canot use the cdc class.
Refer this user guide (section:USB 3.0 Transceiver and USB 2.0 ULPI PHY ) :https://www.xilinx.com/support/documentation/boards_and_kits/zcu104/ug1267-zcu104-eval-bd.pdf
Thanks & regards
Aravind
HI @suddala.s
Thanks & regards
Aravind
Hi aravind,
Thanks a lot for your reply and i can able to detect my sensor as USB CDC class in ZCU104 board by configuring as host mode and no i am trying to read the device node (/dev/ttyACMx) and store the data in a buffer but unsucessfull so far, Can you give any inputs ?.
Thanks in advance,
Sai
