Visitor thommel
ZCU102-ES2 BSP on Petalinux 2017.1
I have recently switched to Petalinux 2017.1 environment, but still have a ZCU102-ES2 development board.
The ZCU102 BSP image for 2017.1 fails to load the FPGA bitstream because of a version mismatch. The older ZCU102-ES2 BSP from 2016.4 fails to build on 2017.1
Will there be a 2017.1 BSP for ES2 silicon or is there a way to rebuild the default FPGA bitstream for the ES2 silicon?
Thomas
Observer rdrehmel
Re: ZCU102-ES2 BSP on Petalinux 2017.1
to flash bitstream to zcu102-ES2 with vivado2017.1 disable version check with :
set_param xicom.use_bitstream_version_check false
with petalinux2017.1, you can boot from SD (create BOOT.bin and image.ub)
(jtag boot hangs on bitstream check, I do not know if it is possible to disable this check)
raph
Observer rdrehmel
