ZCU102 FSBL hangs in boot up
I'm trying to build my own boot images using Petalinux 2017.1 for the UltraZed-EG.  I build linux and package together with an FPGA bitstream, then put this (boot.bin and image.ub) on an SD card boot partition.  When the board powers up, the first two lines of the FSBL come up (as follows), but then nothing.  The FPGA lights operate as expected, so it is reading the card and doing something.
I've had pre-build images working, so the board is ok, any suggestions?
Xilinx Zynq MP First Stage Boot Loader
Release 2017.1   Jun  7 2017  -  08:31:59
Re: ZCU102 FSBL hangs in boot up
It looks that your BSP is not correct. Could you please let me know the ZynqMP revision that you are using?
Make sure you have proper BSP in place.
Best Regards
Shabbir
Best Regards
Shabbir
You were probably correct, I started from scratch (new hdf etc.) and got past my issue.
