ZCU102 Petalinux BSP Interface Listing
I need to know what interfaces are supported by any version of the Petalinux BSPs. For example I need a list that explicitly says that the BSP for the ZCU102 supports I2C, SPI, CAN, UART, etc so that I can be sure it's all included.
It looks like the pre-built Petalinux 2017.4 does not have SPI enabled for example, so I need to know if I enable it that Petalinux can handle it.
Re: ZCU102 Petalinux BSP Interface Listing
Hi @doverstreet6,
For ZCU102 BSP includes below peripherals, you can open the HW design and take a look. I have attached the snapshot of same.
  • Hardware: Design contains Zynq UltraScale+ MPSoC PS block (DDR, UART, SD, QSPI, Ethernet, PCIe, DP, USB, SATA etc.)
  • Software: FSBL, PMUFW, ATF, U-boot, Linux, device-tree(includes open-amp, xen), rootfs(minimal packages).
  • Pre-built Images: Ready to test images bitstream, FSBL, PMUFW, atf, u-boot, Linux and rootfs for booting u-boot and Linux.
Sandeep
Hi @doverstreet6,
Sandeep
