hawthorn_3
ZCU102 TRD 2018.2 DM1 PetaLinux issue
I am currently following the ZCU102 TRD tutorial and when I try building the project I get this error:
$petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
ERROR:  OE-core's config sanity checker detected a potential misconfiguration.
    Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
    Following is the list of potential problems / advisories:
    The TMPDIR: /home/tinros00/rdf0421-zcu102-base-trd-2018-2/petalinux/bsp/build/tmp can't be located on nfs.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
Does anyone have any idea how can I fix it?
Thank you
A PetaLinux Newbie
Tags (4)
hokim
The error message says your tmp directory is on nfs directory.
Use non-nfs directory as tmp directory
You can change your tmp directory using petalinux-config
Yocto Settings -> TMPDIR Location
