ZCU102 TRD 2018.2 build failed (always waiting at pmu-firmware-2018.2+gitAUTOINC+6e82c0183b-r0 do_fetch)
Follow the instructions at
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841801/Zynq+UltraScale+MPSoC+Base+TRD+2018.2+-+Design+Module+1
to build the project, and it always stuck at:
Parsing of 2555 .bb files complete (2516 cached, 39 parsed). 3444 targets, 138 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |##########################################################################################################################| Time: 0:01:18
Checking sstate mirror object availability: 100% |##################################################################################################| Time: 0:00:00
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
Currently 2 running tasks (7337 of 7426) 98% |################################################################################################################ |
0: fsbl-2018.2+gitAUTOINC+6e82c0183b-r0 do_configure - 4220s (pid 26481)
1: pmu-firmware-2018.2+gitAUTOINC+6e82c0183b-r0 do_fetch - 4220s (pid 26484)
I have already waited for several hours, and it can't finish. Does someone meet this problem?
Voyager
Voyager
Re: ZCU102 TRD 2018.2 build failed (always waiting at pmu-firmware-2018.2+gitAUTOINC+6e82c0183b-r0 do_fetch)
You have patience, man
   do ctrl+c multiple times [which will generate signal to terminate the process] to stop the build
and restart the build process [petalinux-build -v] again, it works.
[next time, it might keep looping at fsbl-2017.4+gitAUTOINC+3813f14966-r0 do_configure build, again, repeat ctrl+c multiple times to stop the build process and do petalinux-build -v]
This problem is also there with petalinux 2017.4
i do ctrl+c (multiple times) and restart [petalinux-build -v] it again.
on Ubuntu, it may not give an option to type petalinux-build -v [i will use UP arrow and trigger/run/execute the previous command i.e. petalinux-build -v],
Are you running this within a machine (virtual machine or otherwise) with only a few CPUs, or not enough memory?  Petalinux requires lots of compute resources.  Officially, you need a minimum of 8 cores at 2 GHz each, and 8 GB of RAM, although I've built it on 6 faster CPUs.
I am running on virtual machine. Perhaps it is caused by lack of CPUs and RAM. thanks.
Voyager
Voyager
"Officially, you need a minimum of 8 cores at 2 GHz each, and 8 GB of RAM, although I've built it on 6 faster CPUs"
Congratulations, you've beaten the official minimum. Maybe someone else can do it with a modest quad core, because there isn't any task exclusive of multi-cores, is just a question of patience.
