ZCU102 TRD DM1 petalinux issue
I'm working on ZCU102 ES2 and I try to follow the TRD reference design (rdf0421-zcu102-base-trd-2016-3.zip).
It's my first time with Petalinux and I'm facing an issue.
After installing successfully Petalinux on my Ubuntu, I followed steps in DM1 app.
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2016.3+-+Design+Module+1
At petalinux-build, I get this error message:
~/Documents/petalinux_bsp_dm1$ petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
WARNING: /home/starbreezefrance/Documents/petalinux_bsp_dm1/build/linux/kernel/download/linux-xlnx already exists.
WARNING: Not fetching from remote url!
WARNING: If you want to get a fresh copy, please run 'petalinux-build -c <COMPONENT> -x mrproper'
INFO: Building linux
[INFO ] pre-build linux/rootfs/rpmsg_user_dev_driver
[INFO ] pre-build linux/rootfs/edid
[INFO ] pre-build linux/rootfs/fru_tools
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/gpio-demo
[INFO ] pre-build linux/rootfs/init
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/perfapm_server
[INFO ] pre-build linux/rootfs/tty-vt
[INFO ] build linux/kernel
[INFO ] generate linux/u-boot configuration files
[INFO ] update linux/u-boot source
[INFO ] build linux/u-boot
[INFO ] build zynqmp_fsbl
[INFO ] update linux/arm-trusted-firmware source
[INFO ] build linux/arm-trusted-firmware
[INFO ] build kernel in-tree modules
[INFO ] modules linux/kernel
[INFO ] build linux/rootfs/rpmsg_user_dev_driver
[INFO ] building /home/starbreezefrance/Documents/petalinux_bsp_dm1/build/linux/rootfs/packages-repo/pkgs_sysroot_list
[INFO ] do_gen_sysroot
[INFO ] build linux/rootfs/edid
[INFO ] build linux/rootfs/fru_tools
[INFO ] build linux/rootfs/fwupgrade
[INFO ] build linux/rootfs/gpio-demo
[INFO ] build linux/rootfs/init
[INFO ] build linux/rootfs/peekpoke
[INFO ] build linux/rootfs/perfapm_server
[INFO ] build linux/rootfs/tty-vt
[INFO ] post-build linux/rootfs/rpmsg_user_dev_driver
[INFO ] post-build linux/rootfs/edid
[INFO ] post-build linux/rootfs/fru_tools
[INFO ] post-build linux/rootfs/fwupgrade
[INFO ] post-build linux/rootfs/gpio-demo
[INFO ] post-build linux/rootfs/init
[INFO ] post-build linux/rootfs/peekpoke
[INFO ] post-build linux/rootfs/perfapm_server
[INFO ] post-build linux/rootfs/tty-vt
[INFO ] pre-install linux/rootfs/rpmsg_user_dev_driver
[INFO ] pre-install linux/rootfs/edid
[INFO ] pre-install linux/rootfs/fru_tools
[INFO ] pre-install linux/rootfs/fwupgrade
[INFO ] pre-install linux/rootfs/gpio-demo
[INFO ] pre-install linux/rootfs/init
[INFO ] pre-install linux/rootfs/peekpoke
[INFO ] pre-install linux/rootfs/perfapm_server
[INFO ] pre-install linux/rootfs/tty-vt
[INFO ] install device trees
[INFO ] install linux/kernel
[INFO ] install linux/u-boot
[INFO ] install linux/arm-trusted-firmware
[INFO ] do_gen_baserootfs
[INFO ] install sys_init
[INFO ] install kernel in-tree modules
[INFO ] modules_install linux/kernel
[INFO ] install linux/rootfs/rpmsg_user_dev_driver
[INFO ] install linux/rootfs/edid
[INFO ] install linux/rootfs/fru_tools
[INFO ] install linux/rootfs/fwupgrade
[INFO ] install linux/rootfs/gpio-demo
[INFO ] install linux/rootfs/init
[INFO ] install linux/rootfs/peekpoke
[INFO ] install linux/rootfs/perfapm_server
[INFO ] install linux/rootfs/tty-vt
[INFO ] post-install linux/rootfs/rpmsg_user_dev_driver
[INFO ] post-install linux/rootfs/edid
[INFO ] post-install linux/rootfs/fru_tools
[INFO ] post-install linux/rootfs/fwupgrade
[INFO ] post-install linux/rootfs/gpio-demo
[INFO ] post-install linux/rootfs/init
[INFO ] post-install linux/rootfs/peekpoke
[INFO ] post-install linux/rootfs/perfapm_server
[INFO ] post-install linux/rootfs/tty-vt
[INFO ] package rootfs.cpio to /home/starbreezefrance/Documents/petalinux_bsp_dm1/images/linux
[ERROR] make[1]: *** [package-rootfs-cpio] Error 255
ERROR: Failed to build linux
Any help?
Raphael
Re: ZCU102 TRD DM1 petalinux issue
Hi Raphael
This looks more like environmenr PATH issue, can you please try the below command:
export PATH=/​usr/​bin:/​usr/​sbin:/​etc:/​bin:/​usr/​local/​bin:$PATH
Best Regards
Shabbir
Hi.
I am suffering the exact same issue. I tried this suggestion but got the same result.
Any other thoughts?
Best regards
Clive
Thank you for your answer.
I got the same error.
Console log attached.
BR,
Raphael
Can you post the build.log from /build folder as it may have more details? Could be an environment issue.
Debraj
Find here the build.log file.
Regards.
Raphael
Hi Rapheal
In the build log, I can see the following issue:
 /bin/sh: 1: [: aarch64: unexpected operator
Your /bin/sh probably isn't bash. Looks like this is causing build failure.
Can you please try installing below packages and then re-build:
sudo apt install bash && sudo dpkg-reconfigure dash
Best Regards
Shabbir
Visitor shawnlxf
Hello, when I followed the steps in Zynq UltraScale MPSoC Base TRD 2016.4 - Design Module 1
link: http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2016.4+-+Design+Module+1
% cd subsystems/linux/configs/device-tree
% cp system-dm1.dts system-top.dts
% petalinux-build
I also found some problem. Could anyone help me?
root@sunny-HP-Z640:/home/sunny/Desktop/lxf/share/rdf0421-zcu102-base-trd-2016-4/apu/petalinux_bsp/subsystems/linux/configs/device-tree# petalinux-build
WARNING: /home/sunny/Desktop/lxf/share/rdf0421-zcu102-base-trd-2016-4/apu/petalinux_bsp/build/linux/kernel/download/linux-xlnx already exists.
[INFO ] build system.dtb
[INFO ] building /home/sunny/Desktop/lxf/share/rdf0421-zcu102-base-trd-2016-4/apu/petalinux_bsp/build/linux/rootfs/packages-repo/pkgs_sysroot_list
[ERROR] make[2]: *** [fru-dump] Error 1
[ERROR] make[1]: *** [sub_build_component_/none/apps/multi/fru_tools] Error 2
Visitor wofeicaoge
This is due to the date format.
You can modify the petalinux_bsp/components/apps/fru_tools/Makefile and at line 23
BUILD_FLAGS = -DVERSION=\"$(MAIN_VERSION)\" -DVERSION_DATE=\"2017-06-12\"
of course, the 2017-06-12 can be replaced by any other string you like, but better without blank and chinese words
