ZCU102 Ultrascale+ ATF hangs in SDCard boot using FSBL
I'm having a very hard time trying to get an OS on the Ultrascale+ board. I've managed to do this successfully with the Zynq-7000 series, but it seems like there's a lot of extra things I seem to be missing.
I've used Yocto+Meta-Xilinx to bitbake all the necessary files, except for the BOOT.bin, FSBL.elf, and ATF.elf files. If I generate a BOOT.bin with:
- FSBL.elf
- top.bit
- u-boot.elf
I get the following with a kernel panic: https://gist.github.com/kratsg/ec4fe00cf9beb2bb3f1cb19f2e80dda0. So then I inquired around and it seems like I need ATF. So I ran
bitbake arm-trusted-firmware
which I then included in my BIF
- FSBL.elf
- top.bit
- ATF.elf
- u-boot.elf
and trying to boot the board again from SD card, I see the following https://gist.github.com/kratsg/ec117ace83d1da8e30c34fb7c36e0555 where I'm not seeing a hand-off from ATF to the u-boot. It's not clear if I have ATF correct or what. Links to documentation describing the FSBL for Ultrascale+ step-by-step would be somewhat helpful as I can't find a concrete guide or working example to compare against.
Thanks!
Giordon
Re: ZCU102 Ultrascale+ ATF hangs in SDCard boot using FSBL
Can you copy over your .bif file here?
Debraj
the_ROM_image:
	[fsbl_config] a5x_x64
	[pmufw_image]pmufw.elf
	[bootloader]fsbl.elf
	[destination_device=pl]top.bit
	[destination_cpu=a5x-0]arm-trusted-firmware.elf
	[destination_cpu=a5x-0]u-boot.elf
I'm using 2016.4 and the Xilinx SDK GUI to produce this. Is this related to
https://forums.xilinx.com/t5/Embedded-Linux/2016-3-ZynqMP-zcu102-Wrong-exception-level-in-ATF-BL31-after/td-p/730428 because I don't have exception levels set? I was under the assumption that it was fixed in 2016.4...?
