Observer calex
ZCU102 V1.0 + petalinux 2017.4 : ttyPS1 uart doesn't work
hi all,
i'm doing some tests with jailhouse and i need 2 active UARTs on a ZCU102, ttyPS0 and ttyPS1.
I use the xilinx-zcu102-v2017.4-final.bsp to create a petalinux distro. Everything is fine except ttyPS1.
During the boot, the ttyPS0 is enabled but not the ttyPS1 (see attached boot log file) :
[ 1.470270] Btrfs loaded, crc32c=crc32c-generic
[ 1.475320] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 46, base_baud = 6249375) is a xuartps
[ 1.517457] mmc0: new high speed SDXC card at address 0007
[ 1.517702] mmcblk0: mmc0:0007 SD64G 59.0 GiB
[ 1.518922] mmcblk0: p1 p2
[ 3.116845] console [ttyPS0] enabled
[ 3.120927] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 47, base_baud = 6249375) is a xuartps
[ 3.134560] PLL: shutdown
[ 3.137215] [drm] load() is defered & will be called again
[ 3.143189] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 3.151161] xilinx-drm-dp fd4a0000.dp: device found, version 4.010
when i look at the device files, i see :
root@saumon:~# ls -la /dev/ttyPS*
crw------- 1 root tty 253, 0 Jun 20 17:48 /dev/ttyPS0
crw-rw---- 1 root dialout 253, 1 Jun 20 17:47 /dev/ttyPS1
root@saumon:~#
i have tried to activate  /dev/ttyPS1 with stty, without any success.
It seems (from jailhouse developpers) that both UARTs used to work
before 2016.4.
I use a production ZCU102 V1.0
regards
Observer calex
Re: ZCU102 V1.0 + petalinux 2017.4 : ttyPS1 uart doesn't work
hi Kranthi,
i can make it work.
the uart1 (/dev/ttyPS1) is connected on /dev/ttyUSB1 on my PC,
default speed = 9600.
i can change the conf using
  stty -F /dev/ttyPS1 115200 cs8 -cstopb -parenb
  stty < /dev/ttyPS1
and verify the result with
  echo hello  > /dev/ttyPS1
thank you for all
regards
Hi @calex,
In recent petalinux releases, Uart1 is disabled by default. You need to enable it manually to use it.
1. Add below node in <petalinux project>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
     &uart1 {
                      status = "okay";
2. Then build the petalinux using petalinux-build command
Kranthi
Best Regards
Kranthi
Observer calex
hi Kranthi,
i can make it work.
  stty < /dev/ttyPS1
thank you for all
regards
