chepner
ZCU102 Yocto - BOOT.bin generation
I'm using Yocto 2.4 to generate a Linux OS image for ZCU102 ultrascale+.
After compilation successfully, it generate for me all files separately (atf, u-boot, Image, fsbl ...).
How can I inform yocto to concat all these files and generate the required BOOT.bin file to start Linux kernel after compilation ?
Any help please ?
sandeepg
Hi @chepner,
NOTE: This is something Yocto upstream doesn't support. This is just a hook.
In 2018.x yocto add below variable in local.conf to wire up FIT Image.
# Remove source files after build is finished
# Comment this if you are source or object files for debugging
#INHERIT += "rm_work"
# Specify the HDF location path using local file or subversion path
# Add system HDF/DSA
HDF_EXT = "hdf"
# Using local file
HDF_BASE = "file://"
HDF_PATH = "/2018.1/xilinx-zcu102-2018.1/xilinx-zcu102-2018.1.sdk/system.hdf"
# Using GIT Subversion
#HDF_BASE = "git://"
#HDF_PATH = "<path-to-HDF-in-git>" //ex: HDF_PATH = "github.com/hdf-base.git"
IMAGE_CLASSES_remove = "image-types-xilinx-qemu qemuboot-xilinx"
IMAGE_FSTYPES_remove = "wic.qemu-sd"
EXTRA_IMAGEDEPENDS_remove = "qemu-helper-native"
# Add FIT image dependency
KERNEL_CLASSES += "kernel-fitimage"
KERNEL_IMAGETYPES += "fitImage vmlinux"
# Specify FIT image variables
# Kernel entrypoint and load address is mandatory for FIT image creation
# Load address for DTB and RootFS is optional
UBOOT_ENTRYPOINT  = "0x80000"
UBOOT_LOADADDRESS = "0x80000"
INITRAMFS_IMAGE_BUNDLE = "1"
INITRAMFS_IMAGE = "petalinux-image-minimal"
INITRAMFS_MAXSIZE = "524288"
# Image level user/group configuration.
# Inherit extrausers to make the setting of EXTRA_USERS_PARAMS effective.
INHERIT += "extrausers"
# Add user and password
EXTRA_USERS_PARAMS = "usermod -P root root; "
# Add additional packages to image
IMAGE_INSTALL_append += " \
    dhcpcd \
Sandeep
stephenm
sandeepg
Hi @chepner,
HDF_EXT = "hdf"
# Using local file
    dhcpcd \
Sandeep
chepner
Ok thank you it works.
