Milind
ZCU102 failed to boot with SD card no FSBL loading
Followed documented guidelines from Atlassian.
When tried booting via SD card after copying BOOT.BIN and image.ub file as suggested in below link
Zynq UltraScale+ MPSoC Ubuntu part 2 - Building and Running the Ubuntu Desktop From Sources - Xilinx Wiki - Confluence (atlassian.net)
With current PINs / jumper settings, the UART terminal just shows following and does not boot up.
!! Press ESC to enter System Controller mode.
Nothing happens thereafter.
Also the USB port J96 when connected USB hub using "USB3-USB2A REV1.0" converter does not work / does not show light on USB hub.
Would appreciate your support to resolve this.
Milind.
kdeshwal
Hi @Milind ,
Verify Switch and jumper settings from https://www.xilinx.com/support/answers/68386.html#switch .
Then check if status LEDs on board are ON (on power cycle) from https://www.xilinx.com/support/answers/68386.html#board
Have you checked the board functioning by running BIST test & BIT test ?
If not then firstly verify Board Setup from https://www.xilinx.com/member/forms/download/design-license.html?cid=5375ebb1-d7f7-4971-b703-ebc31d12631e&filename=xtp435-zcu102-setup-c-2019-1.pdf
and then run BIST test & BIT test .
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
Milind
The BIST test failed for except one..
Please advise...
Milind.
kdeshwal
If the board is under warranty, then raise a SR.
This link will guide you for that : https://www.xilinx.com/support/answers/64454.html
Kuldeep
Milind
Dear Kuldeep,
Thanks for the suggestion, and our board is very much under warranty. However, before raising a SR, I request you to kindly validate the board DIP switch especially SW6,8 and 13. The BIST test should not fail due to error in DIP switch settings.
Kind regards,
 Milind.
Milind
I have also run BIT test (BIT.exe) as advise and following is the output.
Can please know how do I get SR raised? I did try from your service portal but I was asked to refer forums. Can I please know how to raise an official SR to get my board issue resolved? Do I have to return the board to repair / recover from a failure?
Please advise at the earliest.
Milind.
