johnfrye11
ZCU104 -- Bad ARM64 Image magic!
Hello I am getting a boot message
reading system.dtb
31506 bytes read in 18 ms (1.7 MiB/s)
Bad  Linux ARM64 Image magic!
ZynqMP>
I am not sure what the problem is here. The boot sequence is obviously reaching U-Boot but for whatever reason cannot get into the oeprating system.
Currently I have the SD card partitioned with two partitions.
I created BOOT.BIN with the command petalinux-package --boot --fsbl <> --fpga <> --pmufw <> --u-boot
The kernel and boot image are configured to live on the SD card.
I put BOOT.BIN, image.ub, and system.dtb on the FAT32 first bootable partition.
I untarred the rootfs.tar.gz on the second partition which is ext4.
During the boot sequence the green light comes on and it seems as though it is booting successfully up to this point in the sequence.
Anyone seeing this and if so could offer some advice?
stephenm
You only need the boot.bin and the image.ub. The image.ub is a fit image that contains the image, dts and rootfs.
johnfrye11
Ok. Now I have two partitions
Partition 1: FAT32
BOOT.BIN
image.ub
Partition 2:
Nothing
Begins booting and I get the message
** Unable to read file system.dtb **
ZynqMP>
What configuration for device tree should I select for petalinux-config? I have it set to SD. Perhaps the problem is there.
stephenm
The dtb should be in the image.ub
Can you share the bootlog? You should see the fit image expand here. It should contain the image, dtb and the rootfs.
sandeepg
Hi @johnfrye11,
Make sure dtb is part of boot image in petalinux-config
petalinux-config -> Subsystem AUTO Hardware Settings -> Advanced bootable images storage Settings -> dtb image settings -> (X) from boot image
# dtb image settings
CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_BOOTIMAGE_SELECT=y
# CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_FLASH_SELECT is not set
# CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_SD_SELECT is not set
# CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_ETHERNET_SELECT is not set
# CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_MEDIA_MANUAL_SELECT is not set
CONFIG_SUBSYSTEM_IMAGES_ADVANCED_AUTOCONFIG_DTB_IMAGE_NAME="system.dtb"
Sandeep
johnfrye11
I believe I tried that before rebuilding the project. I will retry and let you know.
johnfrye11
hey @sandeepg
I do have that configuration set. What should the configurations be for the components:
Subsystem AUTO Hardware Settings:
    boot image settings ---->
    u-boot env partition settings ---->
    kernel image settings ----->
    jffs2 rootfs image settings ----->
    dtb image settings ---->
Image Packing Configuration
  Root Filesystem Type --->
How should SD be partitioned and which files should go on which partitions?
trigger
Voyager
Voyager
Hi @johnfrye11,
You should try to do what @stephenm said -> Load only the image.ub and not the kernel/dtb/ramdisk separatly.
If you really want to boot with dtb you have to unpack the FIT image and try something like that:
fatload mmc 0 0x3000000 Image
fatload mmc 0 0x2A00000 dtb
fatload mmc 0 0x2000000 rootfs
booti 0x3000000 0x2000000 0x2A00000
Cheers,
Trigger
johnfrye11
I have not tried your idea @trigger. I will check that out. I have put the dtb into image.ub but when I boot I get console output similiar to this
https://forums.xilinx.com/t5/Embedded-Linux/IMX274-boot-failed/td-p/886389
 I was able to boot by having root fs as INITRAMFS and not copying and untarring the rootfs on the second partition.
When I try to shut down the system though, it seems like its taking forever for "Unmounting remote filesystems..." . When I preempt it by turning the power off, the changes I made to the filesystem are not persisitent to the next boot.
trigger
Voyager
Voyager
Hi@johnfrye11,
You should try my first solution ;)
According to:
You should also take a look to command line arg and specifically something like root=/dev/mmcblk0pX
Good luck,
Cheers,
Trigger
jschell
I'm having the same problem.  All I can determine is that the error is caused by a problem in the header of the linux Image file.  There is a magic number that is supposed to be in a certain location, and it's not there.  In my case, the number is one byte later than it should be.  I have no idea why or how this can happen.
colombini_luca
Hi @jschell,
  is this problem being solved?
  I am facing exactly the same problem with Petalinux 2018.2 build flow.
  Please let me know.
Luca
colombini_luca
Hi @sandeepg,
   why we can't use system.dtb from SD card?
Luca
jschell
My problem ended up being that I was transferring the image from one system to another using ftp and it somehow got set into text mode instead of binary, so it added a 0x0A after every 0x0D.
colombini_luca
Thanks @jschell!
shabbirk
Hi @colombini_luca@jschell
If the issue have been fixed, I would suggest to mark the appropriate answer thread as an accepted solution, that will help other users looking for solution
colombini_luca
Hi @shabbirk,
   It seems I still have this issue. It seems it is not an issue on file transfer type as @jschell suggested in my case.
   I will report progresses as soon as I will make further experiments.
    Please Xilinx should verify if the linux boot with separated system.dtb and a second partition with rootfs is working or not,
    with a 2018.2 flow.
    Please @shabbirk report about that to the community.
Luca
gudishak
 Hi @colombini_luca,
May I know which filesystem you are trying to boot from U-boot?
Could you please try with rootfs.cpio.gz.u-boot (from petalinux)? Can you share the exact logs?
Kranthi
Best Regards
Kranthi
