ZCU104 DOES NOT BOOT
Hello everyone,
I am trying to boot my ZCU104 board and I followed the following steps to build my project:
1- I created hardware design for zcu106 from .tcl file. I followed the instructions in this URL  (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/115933296/Zynq+UltraScale+MPSoC+VCU+TRD+2019.1+-+Run+and+Build+Flow)
2- I adjusted the design according to zcu104.
3- I exported hdf file.
4- I created BOOT.bin and image.ub files with Petalinux:
petalinux-create --type project --template zynqMP -s <PATH_TO_BSP> --name proj1
petalinux-config --get-hw-description=<PATH-TO-HDF/DSA-DIRECTORY>
petalinux-build -c bootloader -x distclean
petalinux-build
petalinux-package --boot --format BIN --fsbl zynqmp_fsbl.elf --u-boot u-boot.elf --pmufw pmufw.elf --fpga system.bit --force
5- Finally, I coppied BOOT.bin and image.ub files to SD card.
But when I set the board to boot mode and connect to my PC nothing comes up in the console. Can you help me.
Re: ZCU104 DOES NOT BOOT
petalinux-create --type project -s <PATH_TO_BSP>
Can you use the command above? There are two ways to create the project; using the template, or the bsp.
You seem to be using both.
Can you try the images in the prebuilt folder to test your boot?
Hi Stephenm,
Thank you for quick reply. I tried the images in the prebuilt folder to test my boot and there isn't any problem.
Actually I tried to create default project is created by using: petalinux-create --type project --template zynqMP -s <PATH_TO_BSP> --name proj1  ,
and I think that my project modifies the above initial project by using petalinux-config --get-hw-description <path_hdf>. Did I think right? I am new in Xilinx :)
Secondly, Does it any effect if I used both?
If you are using the zcu104 board then you should use
petalinux-create -t project -s <path to zcu104 bsp>.bsp
petalinux-config --get-hw-description=<path to hdf>
If you have a custom board with a zynq ultrascael device on it, then you would do
petalinux-create -t project --template zynqMP -n plnx_project
Using the BSP, will set board specific configs such as the device-tree, and will update the fsbl to
do board init for your zcu104 bord. These would need to be handled manually if using the template.
I have created with petalinux-create -t project -s <path to zcu104 bsp>.bsp. But it still doesn't work.
So, if you do petalinux-create -t project -s <path to bsp>.bsp, then the prebuilt files delivered here work.
However, if you do a
  • petalinux-config --get-hw-description=<path to hdf>
  • petalinux-build
  • cd images/linux
  • petalinux -package --boot --fpga system.bit --u-boot
Then this doesnt work? What doesnt work? Can you share the boot log?
Anything isn't seen in serial terminal.
Hi aysenurakinci805@gmail.com,
Can you please once try to boot with prebuilt images.
and also share your HDF so we can verify it at our end.
Hi Smahalle,
I tried to boot with prebuilt images, and there is not any problem.
I have attached HDF file,
Just to clarify your flow:
cd <plnx proj>
petalinux-build -x mrproper
petalinux-build
cd images/linux
petalinux-package --boot --fpga system.bit --u-boot
Yes, I followed this steps.
