kallensf
ZCU106 BSP mali repo error
On petabuild of xilinx-zcu106-2017.2 BSP, I see:
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master'. Unable to fetch URL from any source.
From a linux prompt, I try:  git clone https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git/
Cloning into 'mali400-xlnx-userspace'...
fatal: unable to access 'https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git/': Could not resolve host: gitenterprise.xilinx.com
Can I modify the build to skip Mali or let me know what the correct git URL is and which script to modify?  Thanks.
kallensf
Just updating what worked for me:
petalinux-build -x clean
petalinux-build -x mrproper
Need to regenerate some config files that mrproper removed:
petalinux-config
petalinux-config will create xilinx-zcu106-2017.2/build/conf/.  Edit local.conf
Replace URL that contains:
SOURCE_MIRROR_URL ?= "http://author.xilinx.com/...
With:
SOURCE_MIRROR_URL ?= "http://petalinux.xilinx.com/sswreleases/rel-v2017.2/downloads"
Save local.conf, then build:
petalinux-build
If you checking sstate takes too long, there's another post in the forum about that.  Hope this helps.
madhuba
MALI kernel URL has been moved by ARM so you need to use the below workaround in local.conf.
INHERIT += "own-mirrors"
Hope that helps
Madhubala
jcfox
Hello madhuba,
I am experiencing the same problem with Mali as described by kallensf. I have attempted to use your workaround by modifying local.conf under the build directory as you suggested but still get:
"ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master'. Unable to fetch URL from any source."
When trying to access the source URL you provided I get a 404 Error. Any advice on where to go from here would be highly appreciated.
madhuba
Could you check your proxy settings,
This link should be accessible
Madhubala
jcfox
Hello again madhuba,
Thank you for your response but I still am having issues visiting https://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace. I tried multiple computers on different networks and am still having problems connecting (server not found). I have also tried just visiting https://gitenterprise.xilinx.com/ with no success as well.
Thank you again.
vineethc
https://forums.xilinx.com/t5/Embedded-Development-Tools/Petalinux-2017-2-rootfs-opencv-libmali-issue/td-p/781570
you have to provide through petalinux-config  ( I tested , working for me )
if you use source mirror URL, use without ?   ( I didnt test though )
kallensf
petalinux-config
With:
petalinux-build
vineethc
http://xkb/Pages/69/69564.aspx
vsavu
This solution does not work for me for 2018.1
The fetch log shows that the mirror is not accessed at all.
trigger
Voyager
Voyager
Hi all and @madhuba @vineethc
Same for rel-v2018.2...
Could you please tell us why on the branch rel-v2018.2 libmali-xlnx.bb is based on git version and not on sumo ?
https://github.com/Xilinx/meta-xilinx/tree/rel-v2018.2/meta-xilinx-bsp/recipes-graphics/libgles
https://github.com/Xilinx/meta-xilinx/tree/sumo/meta-xilinx-bsp/recipes-graphics/libgles
Thank you :)
Cheers,
Trigger
