ZCU106 Petalinux not running
I have been working with the ZCU106 and following the UG1209 Embedded Design Tutorial. I have the proper memory settings. The hello world steps with the a53 and r5 ran fine. I have had no issues until the running the Petalinux image. On the serial output I get:
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 Dec 5 2019 - 17:26:28
Then nothing else.
The large DONE LED has been red throughout this testing in both JTAG boot and SD Card boot dip switch settings.
I have gone through this tutorial using the ZCU102 and had no issues.
Re: ZCU106 Petalinux not running
Also, I am using the ZCU106 2019.1 bsp to build the Petalinux image.
did you find a solution for your problem?
@rschuller_cds
BSP 2019.1, are you using Vivado and Petalinux 2019.1 as well? You must
Yes, I have been using both Vivado and Petalinux 2019.1 as well. I also tried using the prebuilt images contained in the BSP. Those were met with the same results.
do you have any other board to try and discard/ confirm it's a hardware problem, for example, the DDR failing?
After some assistance with Xilinx support it was found that my board has hardware issues and is being RMA'd. Thanks for the responses!
