kallensf
ZCU106 VCU 10G error: XXV MAC block lock not complete
10G on eth1 when enabled results in error: XXV MAC block lock not complete
I booted a zcu106 with prebuilt kernet+rootfs from rdf0428-zcu106-vcu-trd-2019-1_v2\images\vcu_10g
I'm trying to test the 10G port and connected it as shown in 1.1 Board Setup:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/115933277/Zynq+UltraScale+MPSoC+VCU+TRD+2019.1+-+10G+HDMI+Video+Capture+and+HDMI+Display#ZynqUltraScale%EF%BC%8BMPSoCVCUTRD2019.1-10GHDMIVideoCaptureandHDMIDisplay-4AppendixB
On boot, I check if 10G is there using 'ip a' command:
ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
4: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 00:0a:35:00:22:01 brd ff:ff:ff:ff:ff:ff
5: eth1: <BROADCAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:0a:35:03:04:ff brd ff:ff:ff:ff:ff:ff
I try to enable:
ifconfig eth1 up
[ 1875.753065] xilinx_axienet b0001000.ethernet eth1: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
These are prebuilt boot images, so I assumed that device tree and ip port config files are in place.  If not, please let me know how to configure the 10G port.  Thanks in advance!
fred2019
I had the same issue as OP, with precompiled image from rdf0428-zcu106-vcu-trd-2019-1_v2\images\vcu_10g:
root@zcu106_vcu_trd:~# ifconfig eth1 up
[ 52.861085] xilinx_axienet b0001000.ethernet eth1: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
It seems it has been fixed in rdf0428-zcu106-vcu-trd-2019-2\images\vcu_10g [UG1250 from 2019-10-31]: no more warning during ifup, and pinging from PC to ZCU106, and back is working as expected.
Direct link: https://www.xilinx.com/support/documentation-navigation/see-all-versions.html?xlnxproducttypes=Boards%20and%20Kits&xlnxdocumentid=UG1250
Not sure yet what has been modified between the versions.
B.R.,
Fred.
Tags (2)
cone83
I have exactly the same problem but on a custom board. Have you made any progress on this yet?
I have copied exactly the reference design form xapp1305. There has been another thread on the forum with this issue:
https://forums.xilinx.com/t5/Ethernet/Xapp1305-Block-lock-issue/td-p/983861
There it was pointed out that it can be the GT reference clock. I have monitored the clock at gt_refclk_out and can confirm that it matches very well the configured 156.25 MHz. So there must be some other cuase.
I don't think it's the board as we have a partner who is using the same board and got the 10G interface working. I have their Vivado project and they also just copied the reference design. One difference is, however, that they are using Vivado 2019.1 and I already upgraded to 2019.2. I see that in 2019.2 the IP got a new reset input qpll_reset_in, which is not documented in the product guide, but I have already tried all possible ways to assert this reset.
shabbirk
Hi @cone83
Can you please share your device tree changes?
Best Regards
Shabbir
cone83
The device tree for the 10G interface is just the autogenerated one:
ethernet_10g_sub_ethernet_axi_dma_0: dma@a00b0000 {
			#dma-cells = <1>;
			clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
			clocks = <&zynqmp_clk 73>, <&zynqmp_clk 73>, <&misc_clk_0>, <&misc_clk_0>;
			compatible = "xlnx,eth-dma";
			interrupt-names = "mm2s_introut", "s2mm_introut";
			interrupt-parent = <&gic>;
			interrupts = <0 107 4 0 106 4>;
			reg = <0x0 0xa00b0000 0x0 0x10000>;
			xlnx,addrwidth = /bits/ 8 <0x20>;
			xlnx,include-dre ;
		misc_clk_0: misc_clk_0 {
			#clock-cells = <0>;
			clock-frequency = <156250000>;
			compatible = "fixed-clock";
		ethernet_10g_sub_ethernet_xxv_ethernet_0: ethernet@a00c0000 {
			axistream-connected = <&ethernet_10g_sub_ethernet_axi_dma_0>;
			axistream-control-connected = <&ethernet_10g_sub_ethernet_axi_dma_0>;
			clock-frequency = <100000000>;
			clock-names = "rx_core_clk_0", "dclk", "s_axi_aclk_0";
			clocks = <&misc_clk_0>, <&zynqmp_clk 73>, <&zynqmp_clk 73>;
			compatible = "xlnx,xxv-ethernet-3.1", "xlnx,xxv-ethernet-1.0";
			device_type = "network";
			local-mac-address = [00 0a 35 00 00 00];
			phy-mode = "base-r";
			reg = <0x0 0xa00c0000 0x0 0x40000>;
			xlnx = <0x0>;
			xlnx,add-gt-cntrl-sts-ports = <0x0>;
			xlnx,anlt-clk-in-mhz = <0x64>;
			xlnx,axis-tdata-width = <0x40>;
			xlnx,axis-tkeep-width = <0x7>;
			xlnx,base-r-kr = "BASE-R";
			xlnx,clocking = "Asynchronous";
			xlnx,core = "Ethernet MAC+PCS/PMA 64-bit";
			xlnx,data-path-interface = "AXI Stream";
			xlnx,enable-datapath-parity = <0x0>;
			xlnx,enable-pipeline-reg = <0x0>;
			xlnx,enable-preemption = <0x0>;
			xlnx,enable-preemption-fifo = <0x0>;
			xlnx,enable-rx-flow-control-logic = <0x0>;
			xlnx,enable-time-stamping = <0x0>;
			xlnx,enable-tx-flow-control-logic = <0x0>;
			xlnx,enable-vlane-adjust-mode = <0x0>;
			xlnx,family-chk = "zynquplus";
			xlnx,fast-sim-mode = <0x0>;
			xlnx,gt-diffctrl-width = <0x4>;
			xlnx,gt-drp-clk = "100.00";
			xlnx,gt-group-select = "Quad X0Y0";
			xlnx,gt-location = <0x1>;
			xlnx,gt-ref-clk-freq = "156.25";
			xlnx,gt-type = "GTH";
			xlnx,gtm-group-select = "NA";
			xlnx,include-auto-neg-lt-logic = "None";
			xlnx,include-axi4-interface = <0x1>;
			xlnx,include-dre ;
			xlnx,include-fec-logic = <0x0>;
			xlnx,include-hybrid-cmac-rsfec-logic = <0x0>;
			xlnx,include-rsfec-logic = <0x0>;
			xlnx,include-shared-logic = <0x1>;
			xlnx,include-statistics-counters = <0x1>;
			xlnx,include-user-fifo = <0x1>;
			xlnx,ins-loss-nyq = <0x1e>;
			xlnx,lane1-gt-loc = "X1Y12";
			xlnx,lane2-gt-loc = "NA";
			xlnx,lane3-gt-loc = "NA";
			xlnx,lane4-gt-loc = "NA";
			xlnx,line-rate = <0xa>;
			xlnx,mii-ctrl-width = <0x4>;
			xlnx,mii-data-width = <0x20>;
			xlnx,num-of-cores = <0x1>;
			xlnx,ptp-clocking-mode = <0x0>;
			xlnx,ptp-operation-mode = <0x2>;
			xlnx,runtime-switch = <0x0>;
			xlnx,rx-eq-mode = "AUTO";
			xlnx,rxmem = <0x40000>;
			xlnx,statistics-regs-type = <0x0>;
			xlnx,switch-1-10-25g = <0x0>;
			xlnx,tx-latency-adjust = <0x0>;
			xlnx,tx-total-bytes-width = <0x4>;
			xlnx,xgmii-interface = <0x1>;
			ethernet_10g_sub_ethernet_xxv_ethernet_0_mdio: mdio {
				#address-cells = <1>;
				#size-cells = <0>;
The 156 MHz clock is coming in from a dedicated oscillator on the board, so there is no need to program a clock generator.
shabbirk
Hi @cone83
Just for debugging purposes, Can you try adding the attached device tree entries in system-user.dtsi and test if that changes the behavior?
Best Regards
Shabbir
cone83
Hi @shabbirk
I just tested. Still I get the same result:
root@petalinux:~# ifup eth1
[   61.163140] xilinx_axienet a00c0000.ethernet eth1: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
RTNETLINK answers: File exists
fred2019
B.R.,
Fred.
Tags (2)
kallensf
I confirm that I don't see the error and eth1 is up.
alexkeys
Hi. I am having the same issue on a zcu102 board. Do you have any suggestions on how I could fix that? Thanks.
kallensf
xapp1305 covers the zcu102 board.  The prebuilt boot binaries worked for us.
alexkeys
Thanks. I realized I was using the older version. I switched to the 2019.1 version and it works.
cone83
Did anyone yet successfully test it with 2019.2?
kallensf
Yes, 2019.2 vcu trd 10g binaries worked with our zcu106 board.  We're still trying to benchmark properly since the MTU is limiting measured thruput to 1.5G.
ceejliu
Hello @
Did you solve your problem.
I have the same case, and also the reference clock is generated by external crystal oscillator.
