eliezer
ZCU106 hangs after BL31
I am trying to build a ZCU106 Petalinux project from the ground up. I have imported a ZCU106 HDF and left most of the rest of the configuration of the project untouched.
When I try to boot it on my eval board, all I see is this:
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1   Feb 11 2020  -  23:42:53
NOTICE:  ATF running on XCZU7EG/EV/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790
NOTICE:  BL31: Built : 17:57:12, Feb 12 2020
If I try to include the PL bitstream into the BOOT.BIN (by adding --fpga system.bit to the package command) then it hangs after the 2 FSBL lines, not even getting to BL31.
Is it supposed to be easy to build up a ZCU106 project without using the BSP? Are there steps I am missing?
Running Petalinux 2019.1.
aravindb
HI @eliezer
Please use this below petalinux steps to build the boot images.
petalinux-create --type project --template Zynq UltraScale+ MPSoC --name my_proj
petalinux-config --get-hw-description=<PATH TO HDF>
petalinux-build
petalinux-package --boot --fsbl images/linux/zynqmp_fsbl.elf --fpga images/linux/system.bit  --pmufw images/linux/pmufw.elf --u-boot
Note: Please try to boot with  BSP prebuilt  images first to avoid any borad issues, whcih are present in pre-built/linux/images/ folder. I dont think any board issue, since you are able to get till ATF & BL31.
Thanks & regards
Araivnd
aravindb
HI @eliezer
petalinux-build
Thanks & regards
Araivnd
eliezer
Yes, those are the steps I took.
I will try with a BSP and get back to you.
eliezer
I cannot verify that this problem is gone while using the BSP, but I strongly suspect it will be. Marking your comment as the answer.
