beni.falk
ZCU111 PetaLinux 2019.2 RFDC evaluation tool tutorial problems
I am using Petalinux 2019.2 with rdf0476-zcu111-rf-dc-eval-tool-2019-2.zip. My build environment is Ubuntu 18.04.3. I am using the following document: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/130973731/PetaLinux+Build+Tutorial+for+2019.1.
My problems are as follows:
1. When I try to use bootgen per the above document I get the message that the bootgen command was not found.
My path is as follows:
/opt/pkg/petalinux/2019.2/tools/xsct/petalinux/bin:/opt/pkg/petalinux/2019.2/tools/common/petalinux/bin:/opt/pkg/petalinux/2019.2/tools/xsct/gnu/microblaze/lin/bin:/opt/pkg/petalinux/2019.2/tools/xsct/gnu/armr5/lin/gcc-arm-none-eabi/bin:/opt/pkg/petalinux/2019.2/tools/xsct/gnu/aarch64/lin/aarch64-none/bin:/opt/pkg/petalinux/2019.2/tools/xsct/gnu/aarch32/lin/gcc-arm-none-eabi/bin:/home/beni-falk/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
I found bootgen (shell script) under /opt/pkg/petalinux/2019.2/tools/xsct/bin. Should I manually add this directory to my path?
2. The above-mentioned document calls for modifications on top of 2019.1 released BSP. In particular, it calls for adding an entry to project-spec/meta-user/recipes-bsp/rfdc/rfdc_%.bbappend (in the section titled RFDC driver patch information).
In my case I needded to create a new file. I put the specified lines in that file, however the result failed to build - probably need to add some additional data to this file.
3. I originally tried using the ZCU111 BSP provided on the PetaLinux download page (https://www.xilinx.com/member/forms/download/xef.html?filename=xilinx-zcu111-v2019.2-final.bsp) however this BSP didn't include the sources for the RFDC evaluation tool software (rftool). Is the rdf0476-zcu111-rf-dc-eval-tool-2019-2.zip fully self-contained, or should I somehow use both BSPs?
Please advise.
