Visitor angel_rm
[Zedboard] Linux on cpu0 busy when bare metal app on cpu1 starts.
I have a linux running on cpu0 and a bare metal app on cpu1. This app consist in basic program that flash a led when a switch generate an interrupt. I use a Zedboard.
I boot the system correctly and linux works fine. The problem is that when a i start the app on cpu1 (i use the command rwmem.elf 0xfffffff0 0x18000000) the app works fine and if you move the switch on zedboard leds are on and off correctly but the linux doesn't work, terminal is busy a doesn't response.
How can i do that cpu1 works on zedboard and linux continue working on the terminal? Thanks.
Visitor angel_rm
Re: [Zedboard] Linux on cpu0 busy when bare metal app on cpu1 starts.
Solved! I use the PPI and not SPI for the bare-metal app and everything works correctly. Thanks!
Visitor angel_rm
Update:
If i mark the compiler flag -DUSE_AMP=1, app on CPU1 starts and linux continues working but interruptions on app_cpu1 don't work.
How can i do that interrupts works on cpu1 and linux works on cpu0 at the same time?? Thanks!
If I remember right the GIC driver in Linux allocates all interrupts to the CPU running Linux. I think this XAPP below addresses that.
http://www.xilinx.com/support/documentation/application_notes/xapp1078-amp-linux-bare-metal.pdf
John
Visitor angel_rm
