Anonymous
Not applicable
Zedbooard PetaLinux SPI Problem
I want to use SPI1 on zedboard over PetaLinux 2013.10. I have connected SS0 to VCC. Here is my system.dts:
ps7_spi_1: ps7-spi@e0007000 {
            clock-names = "ref_clk", "aper_clk";
            clocks = <&clkc 26>, <&clkc 35>;
            compatible = "xlnx,ps7-spi-1.00.a";
            interrupt-parent = <&ps7_scugic_0>;
            interrupts = <0 49 4>;
            num-chip-select = <4>;
            bus-num = <0>;
            reg = <0xe0007000 0x1000>;
            spidev@1{
                compatible="spidev";
                reg =<1>; //chipselect 0
                spi-max-frequency= <50000000>;
            spidev@2{
                reg =<2>; //chipselect 0
To whom trying to get SPI working:
without bus-num = <0>; kernel panics.
without spidev@1{
devices wil not be listed in /dev
My problem is when I use https://www.kernel.org/doc/Documentation/spi/spidev_test.c this code to test SPI peripheral I get awkward signals. I have attached analyzed signals.
I think I can succesfuly acces to peripheral otherwise I couldn't get any signal. I have played with SPI mode, bits per word and spi speed but nothing has chanced. Also when I use echo asd > /dev/spidev0.1 same signals generated.
Any help appreciated
Anonymous
Not applicable
OK. I found the solution :)
When I use clock value 1048576 = 2^20 and  2^21, it works with frequnecy of 666.7khz and 1333 khz respectively .
But I tried 2^19, 2^18, 2^16, it doesn't work.
