Zynq 7000 USB Custom Board
hello all,
I am using petalinux 2019.1 and I am facing some problems getting usb working under linux. I use USB0 on Zynq, ulpi transceiver is USB3320 from Microchip and there is a USB Hub (2514 from Microchip) connected to it.
When uboot start, if I issue "usb start", usb bus will be correctly enumerated and I can see correct devices using usb info.
When the linux kernel start, however, it loads usb driver correctly but it is unable to enumerate any devices on the bus. If I plug a pendrive onto an usb connector, no messages will arise in the system log, nor on the console.
I try to modify device-tree files, but there are some problems; for example, using this solution (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842272/Zynq+Linux+USB+Device+Driver) throw a "duplicate usb entry" if I modify system-user.dtsi, and I cannot modify system.dtb; it has no effect.
What can be the problem why linux does not enumerate anything ?
thank you very much for any help.
Marco Bisio
Tags (4)
HI @mrcbis_xilinx
Can you please try to change  the MACHINE_NAME as zc702 in DTG settings & build once & try.
Solution 1:
petalinux-config
DTG Settings  --->(zc702) MACHINE_NAME
Solution 2:
In case if  solution 1 not works, please try to add below device tree  changes & verify it.
        usb_phy0: usb_phy@0 {
        compatible = "ulpi-phy";
        #phy-cells = <0>;
        reg = <0xe0002000 0x1000>;
        view-port = <0x0170>;
        drv-vbus;
&usb0 {
       status = "okay";
       dr_mode = "host";
       usb-phy = <&usb_phy0>;
        pinctrl-0 = <&pinctrl_usb0_default>;
Thanks & Regards
Aravind
