Zynq IRQ-ID
you see the Vivado Interrupt configuration window:
The ID-Column Shows the intervals [91:84] and [68:61].
1. If i use only one Interrupt, which ID is used?
2. What is the relation between this ID and the device-tree entry?
3. What is the relation between this ID and the corresponding "/proc/Interrupts" entry?
4. Has UIO any restrictions regarding this ID?
5. Is there an UIO based IRQ-Test-Tool available, to see if an Interrupt is working via uio device?
6. Is there an very simple complete uio example with Vivado design and working Linux app including bsp?
Thank you...
Tags (4)
Re: Zynq IRQ-ID
For 1,2,3 see https://forums.xilinx.com/t5/Embedded-Linux/Relation-between-PL-Interrupts-on-IRQ-F2P-port-of-processing/td-p/275370
Best answer I know of... In short vivado - 32..for long see link
4. Non that I know of
5. Don't know
6. I remeber seeing one for zed board, but not sure.
I know it seem you are still struggling with your uio issue, sorry I don't have a better answer for you
Re: Zynq IRQ-ID
5. Don't know
