Zynq PS I2C Cadence Driver/Device Reset
I am using the Cadence I2C drivers with the ZYNQ PS I2C busses.
It seems my Bus 0 is in a stuck position with both lines high, but I don't want to reset my board in case I don't get it in this state again.
Is there a way to reset an I2C device driver or bus from linux user space? I've tried mmaping the I2C device @ 0xe0004000, and reading the registers, and everything reads 0. The I2C device @ 0xe0005000 seems fine and the registers make sense.
Re: Zynq PS I2C Cadence Driver/Device Reset
You can try to compile Cadence I2C driver as a module and when it stuck - rmmod/insmod it. Zynq MP has a new Reset Controller Driver which can be used but not in Zynq.
https://www.xilinx.com/support/answers/68058.html
Debraj
Can you get dump of IIC registers to get what is the status of each to debug it?
Else, you can enable IIC debug message in kernel configuration.
Praveen
So far I have tried rmmod/insmod the module on another board, but it seems the second time I insmod the driver, the I2C bus is completely unusable, both lines measure high.
On bootup I start the i2c-cadence.ko module automatically, and with
i2cdetect -y -r 0
I can see all my devices addresses listed. I rmmod and insmod the driver, and then I see  none of the devices when I run the command above.
I've looked at the latest I2C cadence driver which has more bus recovery features: https://github.com/Xilinx/linux-xlnx/blob/master/drivers/i2c/busses/i2c-cadence.c  I'd hope this would help when I rmmod/insmod the driver to keep it working.
It requires that the I2C node also be setup to use the pincntrl drivers, but I am unsure how to do this.
My current entry for the i2c node in the device tree is:
		i2c@e0004000 {
			compatible = "cdns,i2c-r1p10";
			status = "okay";
			clocks = <0x1 0x26>;
			interrupt-parent = <0x3>;
			interrupts = <0x0 0x19 0x4>;
			reg = <0xe0004000 0x1000>;
			#address-cells = <0x1>;
			#size-cells = <0x0>;
			clock-frequency = <0x186a0>;
I am unsure how to set up the pinctrl node to also handle the I2C pins (MIO14, MIO15).
Tags (3)
Visitor kentbarker
I am having the same problem, did you find a solution to set up the pinctrl?  If I physically assert the I2C data line low for about 50ms it resets the bus and the zynq I2C controller starts working again. I want to do that from software, from /sys/class/gpio, IOCTL, or something like that if possible.
When  build the kernel, I don't even see drivers/pinctrl/core.c being built, which is where pinctrl_lookup_state() is defined, which the new cadence driver calls to do the bus reset.
