Accepted Solution
Zynq Petalinux hangs on GPIO access
Re: Zynq Petalinux hangs on GPIO access
Have you gone thru this page in detail?
Hello linnj
I want to tell you some detail about my project. I want to send /receive data from Spi and GPIO,
I was using windows 7 and centos i clone the kernal and u-bootand activate the spi
make menuconfig ->device driver ->SPI support -> then enabled xilinx SPI controller common module and user mode spi
I read in tuturail "There is no device tree generator yet for Zynq yet such that hand editing the device tree is the current method."  so i just add these line in the zynq-zed.dts and convert it into dtb
&spi0 {
status = "okay";
and in zynq-7000.dtsi
spidev@0x01 {
compatible = "spidev0.2";
spi-max-frequency = <20000000>;
reg = <1>;
but after running the board
the enviroment is like this I can see spidev after that i tried to transfer data by gpio (simplest case) but i cannot create any gpio node after the following command
root# echo 61>/sys/class/gpio/export
but no gpio connected .
someone in the forum told me that i should move to linux and use petalinux
Now I am using ubuntu 14.04 ,vivado 2015.2 and petalinux.BSP 2015.2 version and working for Xilinx Zedboard 7z020
I created my project and generate the .hdf and .bit file after that export it to SDK
then I create a project using defined BSP
$petalinux-create -t project -s /Downloads/Avnet-2015.2.BSP
get the hardware
$ petalinux-config --get-hw-description=~/my_program/my_program.sdk
run petalinux configuration
subsystem Auto hardware setting->Advance bootable image storage setting and select sd-card for boot image ,kernel image and dtb image setting
in the system-top.dts I add the lines
build the images
generate BOOT.BIN:
$petalinux-package --boot --format BIN --fsbl ~/Avnet-Digilent-ZedBoard-2015.2/images/linux/zynq_fsbl.elf --fpga ~my_program/my_program.sdk/system_wrapper_hw_platform_0/system_wrapper.bit --u-boot
generate rootfs.cpio with the following command because I want to boot the board with sd-card
$petalinux-package --image -c rootfs --format initramfs
IN the sd card copy BOOT.BIN , image.ub and system.dtb into BOOT partition and rootfs.cpio into rootfs partition then run the following command
$sudo pax -rvf rootfs.cpio
In the last boot the board with this sd card
and the result is, I cannot find any /dev/spidev
then i tried to check the gpio then same problem
Now you are saying to follow the
I think problem is in devicetree
should i follow this or
I have to make changes in after editing the system-top.dts (petalinux) or zynq-zed.dts(cent os)
which one is better?
hope you understand my problem
umer.sabeen wrote:
I am also using zedboard  7z020
my pl.dtsi is same like yours.
I found /sys/class/gpio/gpiochip906/ under gpiochip906
cat base
cat label
cat ngpio
but when i am trying to generate
root@Avnet-Digilent-ZedBoard-2015_2:/sys/class/gpio# echo 65>export
root@Avnet-Digilent-ZedBoard-2015_2:/sys/class/gpio# ls
export       gpiochip906  unexport
can you help me where i am doing mistake
With base = 906 and ngpio = 118 the valid GPIO numbers are in the range from 906 to 1023 for this GPIO device. Unless some other device is in that range, 65 is not a avlid GPIO number.
thanks for your reply
it solved my problem at some extent
please have a look at the following code
root@zynq:/sys/class/gpio# echo 1018 > export
root@zynq:/sys/class/gpio# cd gpio1018
root@zynq:/sys/class/gpio/gpio1018# echo out > direction
root@zynq:/sys/class/gpio/gpio1018# echo 1 > value
root@zynq:/sys/class/gpio/gpio1018# cat value
root@zynq:/sys/class/gpio/gpio1018# cat direction
why after echo 1 > value the value of the file is not changing at all
thanks in advance
