Zynq: Run bare-metal application and uboot Petalinux on sequence
I made a Zynq-based board using XC7Z020CLG484-2L, my board has QSPI, SD-Card and EMMC. It can boot petalinux from QSPI and run bare-metal on PS on sequence. I have attach .bif file below.
The process is:
- Fsbl load bitstream and run main.elf (a bare-metal application to init VDMA, sending IIC control Oled display) at first;
- main.elf return and jump to uboot address for petalinux. To do this, I have add C function to bare-metal: atexit((void*)((u32*)0x400000U)); At this step, Oled done initialization and displayed image.
- Uboot copy kernel and petalinux starts executing kernel as usual.
However, between "Starting kernel ..." and "Booting Linux on physical  CPU 0x0", Oled monitor suddenly turn-off and never goes back again! It seem kernel do reset PS and everything gone, except bitstream (done led still High)? (Please correct me if I am wrong.)
All I want to save the booting time by running init program (bare-metal application) at first and then load petalinux.
What must I do if I want to keep PL config (Firmware and bitstream) during the boot process of petalinux?
It quite strange because I successful do the same on Zedboard, petalinux boot from SDcard.
Thank you very much.
The problem is inside my device tree. After I delete some nodes of my cores on PL device tree, Petalinux can boot without reset PL.
@eos_huyvq
Which procedure & petalinux version you have followed in Zed board to boot Linux successfully.
Have you refered XAPP1078 (https://www.xilinx.com/support/documentation/application_notes/xapp1078-amp-linux-bare-metal.pdf)
Kranthi
Best Regards
Kranthi
Hi @gudishak,
Thank you for reply the, I am running Vivado and Petalinux 2017.2. My procedure is:
- Create simple BD with 2 VDMA, Oled monitor controller via AXI IIC on PL.
- Petalinux:
+ petalinux-create --type project --template zynq --name linux_tsan
+ petalinux-config --get-hw-description=/media/HW/project/project.sdk/design_1_wrapper_hw_platform_0
on petalinux config diaglog I change bootargs as 160MB for Linux by mem=160M@0 , I change memory size to 0x0A000000, and finaly I change loadaddr and netstart to 0x02000000. Also change to boot from SDcard.
Thank you for refer me to XAPP1078, alot of infor but it not solve my issue. Because I want to use both core ARM-A9 for video streaming and image processing. Board need to "ready-to-image" on less than 5-7s, so I cannot wait for Petalinux ready after 10s and run myapp-init.
Do you have any suggestion for my issue?
