Observer ain0102
Zynq UltraScale MPSoC Base TRD 2017.4 DM1
Hi.
I am following the wiki posted here.
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.4+-+Design+Module+1
If I do petalinux-build on DM1, I get the following error.
Attach the build.log file as follows.
How do I fix this? please help me.
ERROR: qtbase-native-5.7.1+gitAUTOINC+a55f36211e-r0 do_compile: oe_runmake failed
ERROR: qtbase-native-5.7.1+gitAUTOINC+a55f36211e-r0 do_compile: Function failed: do_compile (log file is located at /data1/hccho/zcu102_trd/apu/petalinux_bsp/build/tmp/work/x86_64-linux/qtbase-native/5.7.1+gitAUTOINC+a55f36211e-r0/temp/log.do_compile.2214)
ERROR: Logfile of failure stored in: /data1/hccho/zcu102_trd/apu/petalinux_bsp/build/tmp/work/x86_64-linux/qtbase-native/5.7.1+gitAUTOINC+a55f36211e-r0/temp/log.do_compile.2214
ERROR: Task (/opt/petalinux/components/yocto/source/aarch64/layers/meta-qt5/recipes-qt/qt5/qtbase-native_git.bb:do_compile) failed with exit code '1'
I am using ubuntu 16.04 and have installed all the dependent packages on ug1144. For example, python, tofrodos, iproute, and so on.
A typical petalinux-build has also been successfully built.
Visitor geff_1
Re: Zynq UltraScale MPSoC Base TRD 2017.4 DM1
Hi:
I found your problom is due to Internet bad condition. So I suggest you to move offline build mode. Reference flow:https://forums.xilinx.com/t5/Embedded-Linux/Doe-petalinux-builds-really-require-internet/td-p/846574.
Then the issue you encounter could be fixed.
But I found other problems I met when I build kernel. I will list following:(my petalinux version is 2018.2)
1. under component dir, device tree directory is missing.
    so you have manually open auto config setting->device tree autoconfig
2. when you package boot.bin, you have to include bitstream file, otherwise boot will stuck at kernel.
Hope it is helpful to you.
Visitor geff_1
I meet the same problem.
Do you fix it?
I check log, it seem petalinux cannot find source from git.
Observer ain0102
I have not fixed it yet.
Visitor geff_1
Hi:
Observer ain0102
Thank you so much for your help.
I'll try it.
