pniklas
Zynq (ZC702) with Lauterbach
I have a ZC702 board in front of me and wanted to flash it with A Lauterbach LA7843 JTAG Cortex A/R Debugger.
I found some information here, how to set the Bootmode Pins switches.
http://www.xilinx.com/support/answers/46881.htm
I downloaded the most recent update for cortex controllers from the Lauterbach homepage.
I received a Lauterbach CMM script which should work with the ZC702 board.
I have a self-built kernel which works fine, when booting from sd-card
(same with ramdisk and dtb)
When I try to load the linux kernel I get the message bus error generated by CPU.
I tried to flash a "normal" application first, which worked without any problems.
Do you have any suggestions what I'm doing wrong?
Is there anyone who is already flashing the kernel using a Lauerbach?
Peter
