Zynq device tree/OPP and power management
We are using Zynq with PetaLinux 2013.10 in AMP mode. I need to add power management by lowering the clock rate as suggested by http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Low+Power+Techniques+part+5+-+Linux+Application+Control+of+Processing+System+-+Frequency+Scaling+%26+More+Tech+Tip I turned on all the CONFIG flags but whenever I add CONFIG_PM_SLEEP, and run petalinux-configure -c kernel, it removes the CONFIG_PM_SLEEP. How do I enable CONFIG_PM_SLEEP in PetaLinux 2013.10? I quickly looked through http://www.wiki.xilinx.com/Zynq+Power+Management but no solution was apparent. It seems like I must also insert OPP numbers into the device tree as described in https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/power/opp.txt How do I find the correct OPP numbers for Zynq? Does it depend on our design, PL, software etc? or is it always the same for all CPUs? I found an example. Is it correct? It is different from the kernel examples. operating-points = <0xa2c2a 0xf4240 0x51615 0xf4240>;
