Zynq u-Boot Support of Micrel KSZ9031
We are booting  a custom board with a Micrel KSZ9031 transceiver using standard u-boot. We are able to get to the u-boot prompt, ethernet linked and seemed to receive packets but would not transmit. I checked the device tree and noticed that we were set for the default
compatible = "cdns,zynq-gem", "cdns,gem";
But if I override it with what it should be (which from the forum here, I have come to believe should be)
compatible = "micrel,ksz9031";
Then no ethernet device is identified at all.
My u-boot config includes the necessary
CONFIG_PHY_MICREL=y
CONFIG_PHY_MICREL_KSZ90X1=y
So I am still missing something - probably in the device tree, my gut tells me.
Any ideas?
Thanks!
Well, the problem turned out to be signal integrity. The Micrel part was able to negotiate a link to 1G and even to receive packets at 1G but failed to transmit at 1G. When I throttled the system down to 100Mb it was all good. There you go.
I would note that on the version of u-boot (and Linux) that I was using specifying
was a mistake and the default
is what is needed to properly ID the PHY
