mharoud
Zynq7020 memory leakage in Linux while receiving periodic messages from FreeRTOS
Hi ;
I am using a Zynq7020 module in a prototype to monitor the thickness of powdered metallic profiles using an ultrasonic sensor.  I am performing now performance testing. Unfortunately, Linux free memory is constantly dropping so I suspected a memory leakage in the software.
I reduced my test to the following basic operation:
CPU1/FreeRTOS is sending every 80 ms a message to CPU1/Linux(generated with petalinux 2018.2). My code does not contain any dynamic memory allocation.
The following is the essence of the code:
FreeRTOS/CPU1 side:
ocm_send_cpu1beat() function is called every 80 ms via a timer callback
void ocm_send_cpu1beat(){
  struct _payload *s_buff=NULL;
  uint32_t s_size;
  s_buff = rpmsg_get_tx_payload_buffer(app_rp_chnl, &s_size, 0);
s_buff->length=480;
s_buff->crc16=0;
s_buff->crc16=makeChecksum_CRC16((int8_t*)s_buff,s_buff->length);
rpmsg_send_nocopy(app_rp_chnl, s_buff, s_buff->length);
Linux side:
Loaded modules
modprobe rpmsg_user_dev_driver
modprobe zynq_remoteproc
Code:
fd = open("/dev/rpmsg0", O_RDWR | O_NONBLOCK);
*bytes_rcvd=0;
memset(readbuf,0,buffsize);
do{
usleep(pollingPeriod);
*bytes_rcvd = read(fd, readbuf ,500);
} while (*bytes_rcvd <= 0);
Free memory estimation:
free -m called periodically in Linux, we are loosing around 40 MB every hour.  The loss is much bigger when the complete system is running.
Any advice?
Thank you in advance
