lim.junhyoung
ZynqMP Ethernet PS RGMII with DP83867E Phy issues
I'm having issues with the Ethernet on a custom board with a ZynqMP and the DP83867E PHY running in RGMII mode.
I can not find the eth0 device in the kernel log. I do not know why.
When the power is applied, the ethernet LED is only green turned on.
[ 2.428427] macb ff0c0000.ethernet: Not enabling partial store and forward
[ 2.429714] libphy: MACB_mii_bus: probed
[ 2.430329] macb ff0c0000.ethernet eth0: no PHY found
Configuring network interfaces... Cannot find device "eth0"
uboot works like this :
Net:   ZYNQ GEM: ff0c0000, phyaddr 9, interface rgmii-id
eth0: ethernet@ff0c0000
U-BOOT for sw
ethernet@ff0c0000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded
ZynqMP> setenv ipaddr 12.12.12.100
ZynqMP> ping 12.12.12.13
Using ethernet@ff0c0000 device
host 12.12.12.13 is alive
my device tree is
&gem1 {
        status = "okay";
        phy-handle = <&phy0>;
        mdio {
                                #address-cells = <1>;
                                #size-cells = <0>;
                                phy0: phy@9 {
                                                compatible = "ti,dp83867";
                                                device_type = "ethernet-phy";
                                                reg = <9>;
        /* pinctrl-names = "default"; */
        /* pinctrl-0 = <&gem0_powerup_mii>; */
        /* phy0: phy@9 {
                reg = <9>;
After booting, type ifconfig command as below.
root@sw:~# ifconfig -a
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1%4882584/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
sit0      Link encap:IPv6-in-IPv4
          NOARP  MTU:1480  Metric:1
shabbirk
Hi @lim.junhyoung
We have an example device tree for RGMII in the below wiki, could you please modify accordingly
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841740/Macb+Driver
lim.junhyoung
@shabbirk
Thank you for your reply.
The link you provided is the link I saw.
The kernel config in the macb driver is already set.
Will there be a change in the device tree?
shabbirk
Hi @lim.junhyoung
Yes you need to m odify device tree as described in the samelink
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841740/Macb+Driver#MacbDriver-Devicetree
lim.junhyoung
@shabbirk
i modify dts. but different problem.
kernel log
[ 3.065844] macb ff0c0000.ethernet: Not enabling partial store and forward
[ 3.067159] libphy: MACB_mii_bus: probed
[ 3.069565] macb ff0c0000.ethernet eth0: Could not attach to PHY
[ 3.103317] macb: probe of ff0c0000.ethernet failed with error -22
my ethernet address is 9. because I have so specified the address in the hardware.
zynqmp.dts
 gem1: ethernet@ff0c0000 {
                        compatible = "cdns,zynqmp-gem", "cdns,gem";
                        status = "disabled";
                        interrupt-parent = <&gic>;
                        interrupts = <0 59 4>, <0 59 4>;
                        reg = <0x0 0xff0c0000 0x0 0x1000>;
                        clock-names = "pclk", "hclk", "tx_clk";
                        #size-cells = <0>;
                        #stream-id-cells = <1>;
                        iommus = <&smmu 0x875>;
                        power-domains = <&pd_eth1>;
system-user.dtsi
&gem1 {
        status = "okay";
        phy-handle = <&ethernet_phy>;
        phy-mode = "rgmii-id";
        ethernet_phy: ethernet-phy@9{
                reg = <9>;
shabbirk
Hi @lim.junhyoung
Did you enable the PHY support in Kernel config (petalinux-config -c kernel) ?
lim.junhyoung
@shabbirk
Yes!!
