so-lli1
ZynqMP - JTAG Port open error. AP transaction timeout
It is not possible to recover the system using JTAG and XSDB. Not even a reset is possible, it always returns "AP transaction timeout". How can this be fixed without a power cycle of the whole board?
so-lli1
stephenm
Do you know the root cause of the issue that is causing this hang? This will occur if you try to access an mem/reg that doent exist.
If the kernal is hanged, then there may not be a solution other than a power cycle. Even if you do a successful reset, and you dont have isolation enabled,
then the system could potential hang if there is an outstanding AXI transaction (for example).
stephenm
Can you try a software reset. The reboot command in Linux, or devmem 0xff5e0218 0x1e
so-lli1
Hi @stephenm,
To be honest, I don't understand what you are suggesting. Since there was a kernel panic, there is no linux available. Both of your commands depend on linux.
However, I tried JTAG access with XSDB to recover without success. As far as I understand issuing "rst -system" command is equivalent to writing to the 0xff5e0218 (RESET_CTRL) register. Tried both, neither worked.
Edit: In order to reproduce, I simply stopped in the u-boot console. JTAG reset... is not working any more, so there must be something I am not aware of that grants the uboot control and blocks me out on JTAG somehow.
Hopefully someone can shed some light on this.
stephenm
so-lli1
@stephenm
Turns out the board I am working with has some pre-production silicon on it and needs to be treated with special care. However, thank you very much for your explanation.
