cdarok2
ZynqMP PL Programming Throught Linux - petalinux 2016.3
Hi!
I´m working on a project with evaluation board zcu102, ZynqMp. I´m trying to load a bitstream from Linux, I already boot Linux from initRam image and following the guide: http://www.wiki.xilinx.com/Solution+ZynqMP+PL+Programming.
After using bootgen for preparing the bitstream into .bin file I copy it throught tftp to the board and after that copy the file to "/lib/firmware/bitstream.bin". Finally, I do "echo bitstream.bin > /sys/class/fpga_manager/fpga0/firmware" and obtain following error:
-----------error log---------------
root@Xilinx-ZCU102-2016_3:~# echo bitstream.bin > /sys/class/fpga_manager/fpga0/firmware
[ 2300.505608] fpga_manager fpga0: writing bitstream.bin to Xilinx ZynqMp FPGA Manager
[ 2300.557560] fpga_manager fpga0: Error while writing image data to FPGA
Don´t know what I´m doing wrong, need some help...
Thanks!
cdarok2
Solved!
The key was solving the bug that exist on  PMU sources on 2016.3 version. Indications on note AR#68246.
Link to AR#68246: https://www.xilinx.com/support/answers/68246.html
(Also this topic is discussed on: https://forums.xilinx.com/t5/Embedded-Linux/zynq-ultrascale-fpga-manager/m-p/755617/highlight/false#M19058)
Thanks guys!
rfs613
Try it with "cat" instead of "echo"... you want to send the contents of the file, not its name.
(Disclaimer: I have not tried this on ZynqMP... only with the older Zynq.)
cdarok2
Hi rfs613,
I tried also "cat" and result is the same ;(
cdarok2
Hi! this is the error that I obtain when doing cat:
----error log ----
root@zcu102-zynqmp:~# cat bitstream.bin > /sys/class/fpga_manager/fpga0/firmware
[  239.374145] fpga_manager fpga0: writing ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ to Xilinx ZynqMp FPGA Manager
[  239.386298] fpga_manager fpga0: Direct firmware load for ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ failed with error -2
[  239.399111] fpga_manager fpga0: Error requesting firmware ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
[  239.410236] fpga_manager fpga0: writing ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ to Xilinx ZynqMp FPGA Manager
[  239.422388] fpga_manager fpga0: Direct firmware load for ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ failed with error -2
[  239.435214] fpga_manager fpga0: Error requesting firmware ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
cat: write error: No such file or directory
Any idea? it seems that the fpga are not connected to PS, but don´t know exactly what I´m doing wrong
thanks
rfs613
Afraid I can't offer much more help, I have not worked with the ZynqMP yet... On the earlier Zynq the process was a bit different ("cat bitfile >/dev/xdevcfg"). But your steps look correct according to the wiki article.
So either your bitstream is problematic (can you try it with a known-good bitstream from Xilinx?), or the instructions in the wiki are incorrect.
You could look at the source code in the kernel for the fpga manager, to see what "error -2" means.
cdarok2
Thanks rfs613, With ZynqMp the workflow is different, it uses other driver...
I still trying to program the FPGA from Linux, it seems that the fpga is not present when trying to load the bitstream... Then the other variable that takes part on the puzzle is the PMU, I´m not using any PMUfw on my boot, then fpga is not starting. I´ll try to compile the PMU firmware with SDK and load again the bitstream... lets see results!
https://forums.xilinx.com/t5/Embedded-Linux/zynq-ultrascale-fpga-manager/m-p/755163#M19015
debrajr
Please verify if the following steps were done to set up the kernel
$ source {PETALINUX_INSTALL_PATH}/petalinux-v2016.3-final/settings.sh
$ petalinux-create -t project -s /proj/petalinux/petalinux-v2016.3_bsps/Xilinx-ZCU102-v2016.3-final.bsp
$ cd Xilinx-ZCU102-2016.3
$ petalinux-config
           linux Components Selection  ---> kernel (xlnx-4.6)  ---> (X) remote .
           linux Components Selection  ---> Remote linux-kernel settings  ---> https://github.com/Xilinx/linux-xlnx.git
           linux Components Selection  ---> Remote linux-kernel settings  ---> master
$ petalinux-config -c kernel
                   Device Drivers  ---> FPGA Configuration Support  --->  <*>   Xilinx Zynqmp FPGA
$ cd build/linux/kernel/download/linux-xlnx
Apply attached Linux patch:0001-fpga-Add-firware-store-function.patch (attached to this post)
$ git am 0001-fpga-Add-firware-store-function.patch
$ cd ../../../../../
$ petalinux-build
Also, if possible use SD Card to mount and use the .bin file.
Debraj
cdarok2
Solved!
Thanks guys!
gouthamp
Hi @debrajr , I have been consistently getting error while trying to write fpga binary file to fpga manager firmware. Error code is 2 and says invalid argument for echo command. I have been trying with petalinux 2016.3 and 2016.4 built and result is same. Following the http://www.wiki.xilinx.com/FPGA+Manager+ZCU102  . Just curious about the patch you have mentioned here. This is to apply for which version of kernel source? Is this patch written to solve this write error to fpga manager firmware?
Goutham
gouthamp
Hi @debrajr , When I apply the patch to petalinux 2016.3 in the process you have mentioned, I am getting :
Applying: fpga: Add firware store function
error: patch failed: drivers/fpga/fpga-mgr.c:171
error: drivers/fpga/fpga-mgr.c: patch does not apply
Patch failed at 0001 fpga: Add firware store function
Cant figure out what is going on here. Should I change the tag of the xilinx git to be 2016.3 and then try again?
Goutham
gouthamp
To me, the patch mentioned here seems to be already included in source tree ,even for 2016.3 tag of xilinx !
