ZynqMP: SD card is write protect
for a custom Zynq MPSoC board we are using a microSD controller with following Vivado settings:
The SD card has no write protect pin.
But the card is recognised only as Read-Only. See Petalinux Output:
[    2.899024] mmc0: new SDHC card at address 0001
[    2.903803] mmcblk0: mmc0:0001 00000 7.30 GiB (ro)
[    2.910559] mmcblk0: p1 p2
Is it possible to disable the write protection?
Andreas
Voyager
Voyager
Hey @andreas.bachmaier,
In the kernel devicetree, you can add disable-wp or wp-inverted to the mmc0 sdhc node.
The first one simply disables the write protection detection logic while the second one inverts the logic.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Hope this helps,
Herbert
