Visitor swordfishman
ZynqMP cannot read/write address space >= 0x80030000
I do not believe this is related to my Custom PL address spaces specifically but more generally in the ZynqMP MMAP/MMU.  See DevMem2 output below.
We have integrated a set of Custom PL in fabric.  These are the same modules I have previously integrated on several Zynq7 devices.  My address spaces are 0x80000000, 0x80030000, 0x80040000, 0x80050000, 0x80060000
I can effectively read/write my 0x80000000 address space using devmem2 and my userspace application via a custom loadable kernel module.
When I attempt to read/write memory addresses > 0x8002FFFF I get a BUS ERROR.  See DevMem2 example output below:
root@REAPR1:~# devmem2 0x8002fffe h
                          /dev/mem opened.
                          Memory mapped at address 0x7f8c956000.
                          Value at address 0x8002FFFE (0x7f8c956ffe): 0x0
root@REAPR1:~# devmem2 0x80030000 h
                          /dev/mem opened.
                          Memory mapped at address 0x7f8f95a000.
                          Bus error
See attached file for DMESG output when user space application executes.  I have enabled a fair amount of debug in my LKM's.  It demonstrates the same issue of memory access < 0x80030000 working but access at or above that address errors out.
My firmware engineer assures me he did nothing to preclude R/W access to these memory spaces but this is our first 2017.2 project.
Any thoughts or experiments are appreciated.
Re: ZynqMP cannot read/write address space >= 0x80030000
Oddly enough after restarting Vivado 2017.2 and re-generating all is well now.  It seems the IP wasn't REALLY in the BIT thus the memory spaces were invalid.
All is working now.  That was an expensive restart.  As a test we pulled out most of our IP and added a new simple block with a single output to drive a an LED.  Our output from the block refused to show up in the block design.  Flailing, and due to past experience, we restarted Vivado and suddenly the block output was present in the block design.  Generating a BIT allowed access to the memory space located above the 0x80030000.  Adding back all previous custom IP blocks rectified all faults.  Memory access and interrupts are flowing from all custom IP to PS.
It may be an IP import tool issue.  The one block that was brought in manually works while the rest were imported from the previous version of Vivado.  I am cautiously optimistic this will fix it but that is tomorrows issue.
Cheers!
Same situation.  synchronous external abort on any access > 0x80030000
Going down the rabbit hole.  If anyone has any ideas we would appreciate them
Be careful of a bug in 2017.2 where exporting a new hdf does not get integrated in an existing sdk workspace. So you end up using an old/stale .bit from an old .hdf.
There is an AR, and maybe a patch but also take a look at https://forums.xilinx.com/t5/Embedded-Development-Tools/Exporting-new-hardware-quot-corrupts-quot-SDK-project/m-p/781003#M42394
