Visitor manas
Zynqmp, U-boot GPIO configuration in custom board
I am trying to configure GPIOs in a custom board based on ZYNQMP ZCU102.
Just to try I wrote the registers from "u-boot/board/xilinx/zynqmp/zynqmp.c"  (board_init()) using the APIs zynqmp_mmio_write and writel (tried both). I couldn't write to these particular register from board_init. However, writing to these register using md command from u-boot prompt is fine.
Registers:
DATA_3 0xFF0A004C
DIRM_3 0xFF0A02C4
OEN_3 0xFF0A02C8
Any suggestion on why the register writing is failing?
Tags (3)
Re: Zynqmp, U-boot GPIO configuration in custom board
Hi @manas,
Try to configure at the end of code before return function.
Praveen
