about DTG Settings in petalinux 2020.1
I am trying to use petalinux 2020.1 and i have a board based on 7z045ffg900
and when i read UG1144 page 25 it says I need to change MACHINE_NAME in DTG Setting
The possible values are: ac701-full, ac701-lite, kc705-full, kcu105, zcu1275-revb, zcu1285-
reva, zc1751-dc1, zc1751-dc2, zc702, zc706, avnet-ultra96-rev1, zcu100-revc, zcu102-
rev1.0, zcu104-revc, zcu106-reva, zcu111-reva
which one should i choose to fit my board?
thank you for your reply!
HI @firesuiry
If your board is not a Xilinx board you do not have to select any of this.
This setting is used to get the DT nodes required for the board peripherals. If you are not using any of these board, it does not make sense to select ny of them.
You can keep the default name or add your custom name
HI @firesuiry
thank you for your help
