add lwip library to petalinux bsp
How to add lwip library to petalinux bsp? I'm trying to test lwip Echo server application. I have downloaded lwip-STABLE-1_4_1 stack and added the require files to c/c++ build settings -> Too; settings -> Microblaze gcc compiler -> Directories.I have added Lwip folder to local repositories list. Still I'm not able to successfully build the application. Kindly help me.
thanks,
mayankara
Re: add lwip library to petalinux bsp
have you got a solution? i try to do something like you
May be this can help: http://www.wiki.xilinx.com/PS+and+PL+based+Ethernet+in+Zynq+MPSoC
Debraj
