Observer hardik123
application development and module adding in Petalinux on zynq board:
environment : Petalinux 2017.2 SDK with libcse support
EVM         : ZC702 Rev 1.
1.When we create a new project in peta linux SDK tool. After creating new project it generated some default apps in /home/eldaas/Desktop/PetaLinux_2017.2.0/Demo_project_zynq/project-spec/meta-user/recipes-apps.
2. The Procedure to include and building the default apps is to include it in root fs by configuring rootfs.
3. By using cmd "petalinux-config -c rootfs" after this command we can see the root structure.
4. The selected app will be enabled and built it using cmd in Petalinux -build.
5. Now i am running it on qemu( emulator) but i am unable to find out where are executables went.
6. i created new module from scratch by petalinux-create -t module --name --enable
so that module is by default added to root system them i gave
petalinux build but now same i am unable to find out .ko file of module in qemu kernel file structure.
Re: application development and module adding in Petalinux on zynq board:
Kernel modules should install to /lib/modules/$(uname -r)/extra
Observer hardik123
root@Demo_project_zynq:/lib/modules/4.9.0-xilinx-v2017.2# ls
kernel modules.builtin.bin modules.order
modules.alias modules.dep modules.softdep
modules.alias.bin modules.dep.bin modules.symbols
modules.builtin modules.devname modules.symbols.bin
there is no  repositery named extra
Sounds like the module is not being installed in your root filesystem image. Either it's not configured to be installed (check project-spec/configs/rootfs_config), or the rootfs image hasn't been rebuilt.
What commands are you using? Specifically, do you call 'petalinux-build' by itself with no additional parameters?
Observer hardik123
we need to repackage all images then only it will show that mistake i was doing
