application for enabling/disabling jtag port through devcfg control register
at the end of xapp1175 (secure boot) there is an interesting suggestion about how to enable and disable jtag port at request from a technician on the field. the xapp suggest to use an interrupt routine that, when pressing a push button, it toogles bit 23 in devcfg control register (address 0xf8007000).
on our custom board we don't have buttons, so I am trying to write a linux application that could do the same.
my problem is, how can I access xdevcfg control register  from userspace?
kernel driver only manages bitstream files loading, if I  access /dev/xdevcfg opening the file or through mmap the board completely reset when I try to read anything.
Best regards,
Rocco
Hi Rocco,
A simple way to access physical registers from userspace is the "devmem" program. It is almost certainly already included. To read the register:
devmem 0xf8007000
To perform a write, where 0x12345678 is the value you want to write:
devmem 0xf8007000 32 0x12345678
If you want to do it from C code, the source code for devmem is easy to incorporate.
Note that devmem program is intended for debugging. If you need to write a lot of data, calling it many times is not efficient. But if you just need to poke a register or two, it is very convenient.
Hi Rocco,
devmem 0xf8007000
thank you very much!
