arping
Is it possible to add the tool arping in our linux image ?
From petalinux-config -c rootfs, base=>busybox, select busybox, and it not be there in my image.
GM.
The "petalinux-config -c rootfs" only gives a small subset of choices related to busybox.
Use instead "petalinux-config -c busybox" to see the whole set of busybox options. From there select "Networking Utilities" and then "arping".
