axi quad spi in standard mode got an error
my block design as figure 0
petalinux auto-generated pl_dtsi  as figure 1
the linux spi device node as figure 2
but after I run the linux app similar to spidev , I got an error as figure 2.
I assume my device-tree is wrong or using the spidev framework is wrong. when I use spidev framework and PS spi controller, everything is good.
Any help is appreciated.
And is there any linux driver or app about axi quad spi core? in standard mode.
3Q,I found my problem and after adding below lines to system-top.dts  there was good news.
&axi_quad_spi_0 {
is-decoded-cs = <0>;
num-cs = <1>;
status = "okay";
spidev@0x00 {
compatible = "spidev";
spi-max-frequency = <25000000>;
reg = <0>;
See if this below SPI driver change works:-
--- a/drivers/spi/spi.c
+++ b/drivers/spi/spi.c
@@ -921,7 +921,7 @@ static int spi_transfer_one_message(struct spi_master *master,
struct spi_transfer *xfer;
bool keep_cs = false;
int ret = 0;
- unsigned long ms = 1;
+ unsigned long long ms = 1;
struct spi_statistics *statm = &master->statistics;
struct spi_statistics *stats = &msg->spi->statistics;
@@ -952,8 +952,12 @@ static int spi_transfer_one_message(struct spi_master *master,
if (ret > 0) {
ret = 0;
- ms = xfer->len * 8 * 1000 / xfer->speed_hz;
- ms += ms + 100; /* some tolerance */
+ ms = 8LL * 1000LL * xfer->len;
+ do_div(ms, xfer->speed_hz);
+ ms += ms + 200; /* some tolerance */
+ if (ms > UINT_MAX)
+ ms = UINT_MAX;
Best Regards
Shabbir
&axi_quad_spi_0 {
num-cs = <1>;
status = "okay";
spidev@0x00 {
reg = <0>;
