bash:No such file or directory
using ubuntu 14 on virtualbox, after i install petalinux, and run source setting.sh
it give me this error
bash: /opt/pkg/petalinux-v2014.4-final/XIL_SCRIPT_LOC=./tools/common/petalinux//utils/petalinux-env-check: No such file or directory
i check the file is under there, not sure how to fix this?
Re: bash:No such file or directory
Properly you have run the command "source setting.csh" before. It would screw up your environmental variables.
Just open a new terminal and type "source setting.sh" again.
if you are running bash/dash then type 'source settings.sh'. If you are using c-shell, then type 'source settings.csh' after opening a fresh terminal like @khoa_pham said
--- Estimated Development time: 2*Pi*(planned completion date) ---
