basic petalinux config can't find "rectangle prope"
I'm new to petalinux, just finished the embedded sys training last week.
Got the petalinux utilities installed on RedHat 7 and am following the instructions on the xilinx wiki for the ZCU102 TRD (DM1).
I get through the petalinux config step, then when I get to the petalinux-build step I get this error:
 gstreamer1.0-plugins-base-1.8.3+gitAUTOINC+8539c9e868-r0 do_fetch: Fetcher failure: Unable to find file file://0001-video-overlay-Add-helpers-for-render-rectangle-prope.patch anywhere
It then lists all the paths it searched, all of which are in my zynq install directory (i.e. it's not a firewall/proxy situation where it's searching online at the git repo).  Can anyone adivse what I can try next?  TIA
Re: basic petalinux config can't find "rectangle prope"
HI Benmishoe,
Can you please share the full logs, so that it will be easy to understand.
Your host system should  have below mentioned installation requirements to build the petalinux project.
refer this link :https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1144-petalinux-tools-reference-guide.pdf
section "Installation Requirements".
From the logs looks not finding the patch in repository.
Thanks & regards
Araivnd
Hello @benmishoe,
please install the following package:
e.g.
sudo apt-get install gstreamer1.0-plugins-base
 Based on the error you showed, I suppose it should work! let me know if it helped.
\Razi
-- Don’t forget to Reply, Kudo, and Accept as Solution --
Hello @rsey,
Thanks for the reply, and I apologize for the delay.
In this case, the OS is reporting that gstreamer is already installed and there is nothing to do.
I attached the log file of the failure.  Any help would be greatly appreciated.
Hello...does @aravindb or anyone else have any thoughts on what's causing this?  thanks in advance...
